Cleaning SSR wheels
Old Mar 28, 2005 | 07:37 PM
weaverpsu's Avatar
weaverpsu
Cleaning SSR wheels
I have gook on my SSR Comps. It could be tar. How do i get it off without scratching the wheels? I already scratched them a little bit somehow. Any way to get scratches out? Can they be waxed out? I tried a search but it was exhausting. Thanks
Old Mar 28, 2005 | 07:39 PM
lwlam's Avatar
lwlam
WD40.
Old Mar 28, 2005 | 08:10 PM
agranger's Avatar
agranger
WD40 is a good start. Use a soft microfiber cloth.
Turtle Wax has made a product for years... Bug and Tar Remover. It is chock full of solvents, so you will have to re-wax afterwards, but it does a great job.
If you can get the bulk of it off, you could use a clay-bar to touch up the area and remove the rest.
Old Mar 29, 2005 | 07:44 AM
BradB's Avatar
BradB
Tarminator by Stoners is also great. Any of these ideas should do the trick. But the key, as agranger said, is to use a soft microfiber towel to avoid scratches.
Old Mar 29, 2005 | 08:14 AM
VoiD's Avatar
VoiD
clay can do wonders also.
Old Mar 29, 2005 | 04:29 PM
weaverpsu's Avatar
weaverpsu
thanks a lot. i have a tar remover already so ill give the wd-40 a try first and then that. any way to polish out scratches on the wheels? is wax strong enough? im gonna do it tomorrow it is supposed to be nice here in Jersey. Finally
Old Mar 29, 2005 | 06:00 PM
agranger's Avatar
agranger
If the wheels are painted, wax will remove some scratches (a good old-fashioned cleaner wax that is... something with an abrasive). Scratch-X (Meguiars), swirl mark remover (very light compound) and rubbing compounds may also work (in order of increasing agressiveness).
You should always start with the least abrasive product and try it... if that doesn't work, go up one notch and try again. Check your work frequently. Rewax/seal when you are done.
All of the above is for a painted wheel. Someone with alloy experience will have to help you with those... I'm out of my depth on that subject.
Kimolaoha
Dec 5, 2020 09:32 PM
phrza81
Oct 10, 2015 11:37 PM
Overpolished
Detailing 101
15
Aug 21, 2015 07:19 PM
jrezzo
Aug 9, 2015 10:32 PM
