Cleaning Wheels
Old May 22, 2021 | 09:50 AM
Dan_C_in_NJ's Avatar
Dan_C_in_NJ
Cleaning Wheels
So I have a detailing question. 2010 R55 with black wheels. Bought a year or so ago but the wheels have what looks like a metal brake residue imbedded in them. I've cleaned the wheels when washing the car but the "rust" tint still shows up. What can I do to clean them up? Any help is appreciated. Image attached to help to see the residue.
Dan.
Old May 22, 2021 | 09:59 AM
FakeName's Avatar
FakeName
Optimum Ferrex.
Amazon Amazon
Old May 22, 2021 | 06:29 PM
Fly'n Brick's Avatar
Fly'n Brick
clay bar
Old May 22, 2021 | 06:43 PM
mountainhorse's Avatar
mountainhorse
Amazon Amazon
Works well.
Old May 22, 2021 | 06:53 PM
bratling's Avatar
bratling
Super Moderator
The two three who posted before me are both correct! You’ll want an iron neutralizer, which will dissolve a lot of the brake dust, and a clay bar to remove the rest of the stuck in particles.
Start with a simple wash to get the grunge off the wheels.
Then use an iron remover such as Iron-X by CarPro (my favorite of all the ones I’ve tried). Spray it on, let it dwell for a couple minutes, rub with sponge, then hose off. Those wheels look like they may want a couple rounds of this.
next, get yourself an automotive paint clay bar. Pretty much any brand will do; they all are basically the same sort of sticky polymer clay. Tear off a piece the size of a quarter or fifty cent coin, spray wheel with a shot of your favorite quick detailer (or a dedicated “clay lube” if you want to get fancy). Rub the clay across the wheel surface. Check for dirt pick up. There will be a lot. Fold the clay to get a clean surface. Repeat. Over and over. As you use it with clay will get loaded up with dirt; at some point you’ll want to toss it out and tear a new piece off your block of clay.
(another reason to use small bits of clay at a time... when you drop it, it will pick up all the grit from the road/driveway/garage/ground under it. And you will drop it. When you do, throw it out. Don’t drag that grit and rock over your paint!)
with some elbow grease and patience, you’ll have the wheels back to shiny clean! Consider applying a protectant of some sort. That can be as simple as good old car wax. The point is to give the new brake dust a surface other than the paint to stick to. That makes removing the dirt much easier next time!
Last edited by bratling; May 23, 2021 at 12:37 PM. Reason: Mountainhorse got there first!
Old May 22, 2021 | 07:28 PM
Dan_C_in_NJ
Thanks for the replies.
I am changing out the brakes, shocks and struts soon so this will be added to the To-Do list.
Old May 22, 2021 | 08:07 PM
Fly'n Brick
Originally Posted by bratling
The two who posted before me are both correct! You’ll want an iron neutralizer, which will dissolve a lot of the brake dust, and a clay bar to remove the rest of the stuck in particles.
A big +1 on the clay bar procedures
Old May 23, 2021 | 08:21 AM
Capt_bj's Avatar
Capt_bj
just some FYI
black, white and most silver wheels from MINI are painted and clear coated same as the bodywork .....
while use of special chemicals to deal with baked on brake dust is often required, in general the care of the finish so no different than the bonnet!!!! And if the dust is (was) SO bad that the finish is pitted ..... wellllllll ....
wheel silver: code A54 SW formula79742 ,Wheel Brt Silver Met
wheel black: 668, 59049, Miscellaneous, Jet Black,
wheel white: 899 64706 Miscellaneous Aspen White
from the Sherwin Automotive Paint database .....
Old May 23, 2021 | 11:30 AM
Dan_C_in_NJ
Capt,
This is the part that I want to not think about. I am HOPING that the surface is not too bad.
When I am in the midst of the changeover, I will find out. Till then I don't want to even swipe a finger across the surface. We will see how it goes.
Although there is a bit of road rash on two wheels , so I have an excuse to get the wheels powder coated. And of course, new tires would be necessary.
Mission creep at it's best.
Dan
Old May 24, 2021 | 11:01 AM
crazy4trains's Avatar
crazy4trains
As mentioned above Iron-X has worked well for me.
Jake Renninger
Nov 16, 2017 06:34 PM
minimic
May 29, 2012 05:23 PM
w00tMINI
Detailing 101
Mar 14, 2011 04:07 AM
Mini_Freak08
Tires, Wheels, & Brakes
Apr 22, 2006 08:36 PM
frails
Detailing 101
Oct 10, 2002 08:07 AM
