Removing airbag warning sticker
Old Dec 5, 2002 | 04:39 PM
SoopaCoopa's Avatar
SoopaCoopa
When I pulled the airbag warning sticker off of the dash, it left a slight amount of goo behind. I've got the alloy patina dash on my MCS. Can I use some GooGone on it, or can someone recommend another cleaner?
Old Dec 5, 2002 | 04:46 PM
sirron's Avatar
sirron
Did you also take labels off your mattress? The mattress label police will be after you....and now the airbag label police too!!! Gunk-off works fine.
Old Dec 5, 2002 | 04:48 PM
MiniChristina's Avatar
MiniChristina
GooGone should work just fine.
Old Dec 5, 2002 | 06:20 PM
friedduck's Avatar
friedduck
I used wd40 without problems.
Old Dec 5, 2002 | 07:01 PM
Sarcux's Avatar
Sarcux
Googone, Laquer Thinner, Acetone (nailpolish remover), Adhesive remover, paint thinner, WD-40, cleaner/degreaser....
Old Dec 5, 2002 | 07:10 PM
sirron's Avatar
sirron
I'd be really leery about using laquer thinner or acetone. I believe you'll at least take the finish off the plastic, maybe even start to melt it.
Old Dec 5, 2002 | 07:19 PM
ADVANTAGE's Avatar
ADVANTAGE
soapy warm water works just fine.
Old Dec 5, 2002 | 08:39 PM
Sarcux's Avatar
Sarcux
Well, yeah, they would eat through, if you let it sit. Quick applications should be fine, just don't use it on your paint job, lol.
Old Dec 5, 2002 | 08:45 PM
PittsburghMark's Avatar
PittsburghMark
Spit and a shirt sleeve will do it.
Old Dec 5, 2002 | 08:50 PM
W3IWI
WD40 is my choice also. The other solvent that works wonders is 91% Isopropyl Alcohol (IPA), available at local pharmacy. And IPA removes the oil film after you use WD40 to get the goo off!
Old Feb 1, 2003 | 07:26 PM
Yucca Patrol's Avatar
Yucca Patrol
As a retired polymer chemist, I would suggest alcohols over the aromatic organic solvents such as acetone. I will be using the same 91% USP IPA to remove mine.
On my VW GTI, I tried the acetone despite all of what I knew about solvent/polymer compatability, and kind of melted the finish of the visor.
Need some WD40 in the house anyway, so I will pick up a can and check it out too!
Old Mar 12, 2003 | 10:47 AM
mpemburn's Avatar
mpemburn
I was searching to see whether people removed the stickers or left them when I found this thread. Guess it's okay as long as nobody tells the sticker cops . . .
I have a suggestion that involves no solvents at all: Get some fairly low-tack tape (like masking tape) and make a loop of it sticky-side-out. Dab the tape at the adhesive goo and it will miraculously leave the surface it was stuck to and grab the tape. I've used this to good effect on some fairly delicate surfaces.
Peace,
Mark of Pemburnia
madmaxxed
Aug 24, 2015 11:56 PM
greekzilla
Aug 23, 2015 03:44 PM
one73ronin
Aug 19, 2015 12:36 PM
quality_sound
Aug 7, 2015 09:36 AM
