Remove Wax residue from Wheel molding
Old Nov 5, 2013 | 08:54 AM
  #226
jaxdw57's Avatar
jaxdw57
Belive it or not...WD40 it will not harm the finish of your paint or plastic trim. It works to remove tar, bugs, tree sap, ect. Check out WD40.com 2000 uses for WD40...it works and it's cheap. And I'll bet already in most everyone's garage.
Old Jan 20, 2014 | 10:05 PM
  #227
iMike's Avatar
iMike
Didn't read the whole thread. Did anyone mention pencil eraser? Plain pink eraser does it for me. Then Meguiar's Hyperdressing on the black trim.
Old Apr 25, 2014 | 12:02 AM
  #228
Gearheadaddy's Avatar
Gearheadaddy
Originally Posted by minilovr
I found that after the first wash the dust problem went away.
I use Back to Black. Wipe on. Let dry about 5 minutes. Buff with clean cloth. Dirt won't attract as easy...
Old Dec 7, 2014 | 01:19 PM
  #229
russmini's Avatar
russmini
Originally Posted by ninja turtle
Jiffy Peanut Butter works just fine.
I was rather skeptical of the peanut butter technique until today. This morning I noticed areas of wax residue as well as a cosmoline drip down the right front wheel arch. Tried rubbing alcohol with marginal results. Then decided to use peanut butter and damn it works! Cosmoline is gone as well as the wax residue.
Old Dec 7, 2014 | 09:07 PM
  #230
Gearheadaddy
Back to Black
Meguiars Back to Black returns the plastic arches to black as new..
Old Dec 8, 2014 | 05:52 AM
  #231
russmini's Avatar
russmini
May have to try back to black but still using Black Wow which does a good job.
Old Dec 8, 2014 | 03:59 PM
  #232
mbu's Avatar
mbu
Wait until it gets dusty out and see if your "damn it works" reaction is still there!
Old Dec 8, 2014 | 04:09 PM
  #233
russmini's Avatar
russmini
Have you used peanut butter?
Old Apr 20, 2015 | 04:33 AM
  #234
fastzombie's Avatar
fastzombie
My new to me 2012 had some wax residue on the textured black bits. This weekend I tried a nice new soft toothbrush with rubbing alcohol. It worked extremely well on the areas that I suspect were newer wax spots. A few areas it didn't get rid of the haze. So I tried peanut oil on those areas and it worked really well.
Old Apr 20, 2015 | 07:43 AM
  #235
Gearheadaddy
Plastic Treatment
I use Meguiars Black Wax in a spray bottle on my Midnight Black Metallic Mayfair S paint and "Back to Black" plastic treatment made specifically for all color plastic trim pieces. Back to Black needs to be applied with a rag, left for 5 minutes and wiped smooth. 3 coats on 3 year old plastic returned my car's black plastic trim to "new". Took me about an hour tops to do the whole car. I treated it again with one coat 6 months later...
Old Feb 12, 2018 | 08:26 PM
  #236
OGwoody's Avatar
OGwoody
So I'm new to the boards and wanted to ask if anyone else has seen this stuff coming out of drain holes throughout their MINI? I've seen it under the hood in crevices, and in places around doors. The areas under the hood seem to warm up after a drive, and can be wiped with a damp rag. At first I thought it was bugs that were trapped or hiding, and we're getting cooked in the engine bay. It's a mix between tree sap and a wax substance. The front fender trims started to show signs of a drip from under the hood crevice.
(Tried to create a thread, to no avail)
wkp1219
Nov 13, 2015 07:52 AM
ltjpunk7
Sep 6, 2015 07:32 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
Dashdog
Aug 10, 2015 06:17 AM
