Remove Wax residue from Wheel molding
Old Sep 22, 2007 | 08:48 PM
  #151
jf7fsu's Avatar
jf7fsu
THe Magic Eraser gets all resideue off with no fuss and no muss. You don't need all those oils and chemicals. 1-2-3 gone. Available in your local supermarket.
Old Nov 17, 2007 | 05:39 AM
  #152
Beebe's Avatar
Beebe
I had some pesky wax residue on the highly textured plastic along the roofline. BW did not take it off, peanut oil did not take it off. I even tried some of the more unique suggestions like mineral oil. What finally worked was 91% isopropyl alcohol scrubbed with a toothbrush (leaves it looking pale and dull) followed by cleaning with Wizard's black renew (again with the toothbrush) and lastly Black Wow (sesame seed sized speck).
I've found Black Wow to be an excellent protectant against getting wax on the plastic in the first place.:impatient I'm not having any of the dust attracting issues that some have mentioned.
Old Mar 9, 2008 | 06:51 AM
  #153
fastfritz's Avatar
fastfritz
Clean WAX off wheel trim.
Sure fire way. Use peanut butter on waxy spots. Apply a little and wipe it off. Works every time. Two caveats, Don't use chunky and dogs will sniff
and lick your trim. Try it it works.
FastFritz
Old Mar 11, 2008 | 11:41 AM
  #154
aznqtboy984's Avatar
aznqtboy984
I just used the peanut butter method this past weekend. I was very surprised how fast and easy the wax residue came off.
Old Mar 11, 2008 | 11:46 AM
  #155
MiniMaybee's Avatar
MiniMaybee
Yup peanut butter works. Now a better use of our time would to be figure out the scientific reason for this and to concentrate the effective component - thus eliminating the dog issues.
Old Mar 28, 2008 | 09:01 AM
  #156
accce's Avatar
accce
Mr. Clean eraser
Old Mar 28, 2008 | 12:05 PM
  #157
greengobln's Avatar
greengobln
peanut oil
Old Mar 28, 2008 | 02:26 PM
  #158
lotsie's Avatar
lotsie
One would think that the oil in it is the reason, but others think it is dogs licking it off I don't think the 2 can ever be separated
Mark
Old Mar 28, 2008 | 02:48 PM
  #159
accce's Avatar
accce
http://www.homemadesimple.com/sites/...ra_power.shtml
magic eraser
oil just covers the stuff up
Old Apr 10, 2008 | 10:05 PM
  #160
loadtoad's Avatar
loadtoad
Had anybody tried using peanut butter or alcohol on the soft trim around the roof of the car? That is where I have the nasty white wax residue and wanted to get some feedback before I go buck wild.
Old Apr 11, 2008 | 08:13 PM
  #161
checkercoop's Avatar
checkercoop
I have found griots rubber cleaner to get the wax off the trip around the roof pretty good...does require some scrubbing, but it gets the caked on wax off nice
Old Apr 13, 2008 | 09:51 AM
  #162
Goodwood's Avatar
Goodwood
caked wax on paint?
All you folks seem to have some good ideas for removing wax from trim, how about from paint?
I have numerous tiny, tiny rock chips on the front of the bonnet, very common... when I wax the car the wax stays in those little pinhole sized chips and turns white... not very pretty on Velvet Red or British Racing Green... if I ever get another MINI it will be Pepper White, so the wax will just blend in! But I digress....
1) What's a good way to get the wax out, then
2) How can I wax the bonnet so as not to start the whole process all over again?
I've tried rubbing alcohol and a wash-cloth to get the wax out, doesn't seem to harm the paint, evaporates quickly, but doesn't do a great job removing the wax.... maybe I just haven't tried long enough?
Old Apr 13, 2008 | 10:25 AM
  #163
lotsie's Avatar
lotsie
Goodwood, alcohol will work, or dawn soap, depending on what wax you are using. Use a toothpick to work it out. You really should fill those chips with paint though. You can get touch-up paint from the dealer, just don't use the brush that comes with it, loads to much paint. I use a toothpick, putting 2-3 thin layers on. I also have a BRG.
Mark
Old Apr 13, 2008 | 10:33 AM
  #164
Goodwood's Avatar
Goodwood
no good with touch up
I've never been any good with touch-up paint... I always get too much and that's no good. I was hoping to find a way to get the old wax out and find a new wax that doesn't dry white.
The chips are small enough and light enough so that they're just in the clear-coat. None of them go through to the primer or metal. They're all just big enough to hold on to the wax when I buff... and I'm talking about 40-50 or more of these little things.
I suppose I could polish them all out, but I always like to start with the least aggressive way first.
Anybody know of a wax that dries clear? A decade ago when I was into BMWs, everybody used a two-stage Zymol product... clean the paint then wax it... I've still got some of that Zymol wax, but it won't stick or bond with the paint unless the paint has been cleaned perfectly... I may try that if I can get the old wax out. I'll try the Dawn you suggest.
Old May 12, 2008 | 05:16 AM
  #165
IamPullied's Avatar
IamPullied
Lysol wood cleaner, takes off anything on the plastic
Old May 12, 2008 | 08:08 AM
  #166
MINIFVR's Avatar
MINIFVR
I am very happy I stumbled upon this thread...I just Epic'd my car again last week and after I was done that old turtle wax res that was on the trim the year before stood out like no other. I now have quite a few options to choose from.
Old May 19, 2008 | 08:37 AM
  #167
MINIFVR's Avatar
MINIFVR
I tried the peanut butter job and it didnt work, hardly at all. Im going to try IA next.
Old Jan 9, 2009 | 06:40 AM
  #168
kkcshipp's Avatar
kkcshipp
Magic eraser from Mr. Clean takes it off in seconds and there is no residue. The great thing is you can use it on all your vinyl surfaces and seats inside the car also. Don't know what they are made of and I don't care, IT WORKS! I used it to get finger marks off my interior windshield pillars, and annoying marks off my door panels and I didn't get tennis elbow to do it. I read on here where somebody was going to mask off their care with tape? C'mon, get a box of these at your local Wal-Mart or elsewhere. Too Easy!
Old Jan 9, 2009 | 11:27 AM
  #169
MeliaAndSam's Avatar
MeliaAndSam
Slightly veering off the subject:
http://en.wikipedia.org/wiki/Melamine_foam <--magic eraser
But yeah, I've got those white marks on our trim right now, and it sucks. Used BW prior to waxing too. I'm gonna try the PB solution first...mainly because it sounds tasty.
Old Jan 9, 2009 | 12:10 PM
  #170
kenchan's Avatar
kenchan
magic eraser is an abrasive foam. it will remove paint and surfaces.
Old Jan 9, 2009 | 06:08 PM
  #171
OctaneGuy's Avatar
OctaneGuy
What wax did you use that you got those marks from? And while it's great you used BW, did you wipe off the wet wax from the BW treated trim? Or did you leave it on to dry? All the BW does, it make the wax/polish easier to remove.
Old Feb 11, 2009 | 12:40 PM
  #172
kkcshipp's Avatar
kkcshipp
Read the Wikipedia message and great, but it works and none of my paint was harmed in the process. I'm not trying to take wax off my clear coat. It gets the wax off...With the chips from rocks etc. it can't harm that plastic. I'm going to order some Black Wow off Amazon though because I saw the video of it. Wished it were in my local Autozone so I wouldn't have to pay shipping etc. though.
Old Feb 11, 2009 | 12:44 PM
  #173
kkcshipp's Avatar
kkcshipp
BTW, I use it on the plastic on my Jeep Wrangler also and plan on using the Black Wow there because it sits in the weather all day. Does BW work on restoring (my term) the rubber molding around windows of the doors? My wife's car moldings (pure rubber) has seen better days.
Old Feb 11, 2009 | 01:36 PM
  #174
OctaneGuy's Avatar
OctaneGuy
BW was designed and intended for us on plastic, not rubber. You can use it there, but you will most likely be disappointed in how long it lasts on rubber.
Richard
Old Feb 11, 2009 | 04:08 PM
  #175
kkcshipp's Avatar
kkcshipp
I'm still going to buy it. I'll wait for you to invent the other.
