Soft Touch Auto Dryer
Old Jul 24, 2004 | 11:00 AM
danbanger's Avatar
danbanger
I bought this http://www.autopia-carcare.com/kit-washtrio.html and I was wondering if the Soft Touch Auto Dryer was safe to use on the car. I think I may just be using it to clear off most of the water off the glass. It's made by Viking if that helps.
Old Jul 24, 2004 | 11:49 AM
rg's Avatar
rg
i've read on here before that others are using things like this. my big concern is if some dirt or grit or something was in the way it's going to get raked across the finish. i've tried the Mr. Clean AutoDry with very so so reslults, so once i've used up what i bought it's back to a good old towel for me!
Old Jul 24, 2004 | 06:21 PM
BradB's Avatar
BradB
danbanger: I am have this product. In fact I have all Viking products. Viking is based in St. Louis and I just hosted a detailing event there.
This squeege is a high quality product for glass but I would not use it on paint for a couple reasons. The blade is very thick and relatively inflexible. The blade is also just flat at the end. This means to get maximum efficiency you need to press firmy to bend the blade and scoop the water. This pressure against the painted surface is a bad thing in itself. Combine that with the risk of getting a piece of debris in it and it could be disasterous.
If you compare this to the California Water Blade, for instance, the CWB is "T" shaped at the end which acts as a natural scoop for the water. The end is also very thin and flexible so you don't have to press as hard against the surface. There is still a risk of debris catching.
The best bet is still the Waffleweave Microfiber.
vulkandino
Oct 31, 2015 08:29 PM
cub4bearindiana
Oct 2, 2015 09:45 AM
Oct 1, 2015 12:13 PM
kevinlhr310
Sep 27, 2015 02:31 PM
