under hood wash
Old Aug 1, 2012 | 05:24 AM
MiniS2010's Avatar
MiniS2010
under hood wash
Hi
I,m living on dusty place all the year , also very high Temp ( 50C )
How Can I wash under my hood ,
Should i used water only
or special material
should I cover electronic part if yes can u guide me
Old Aug 3, 2012 | 02:56 PM
Capt_bj's Avatar
Capt_bj
you are PROBABLY ok using a coin operated "wand" place as long as you stay 2 feet back with the wand
Old Aug 3, 2012 | 05:34 PM
Psquared's Avatar
Psquared
^a little Simple Green couldn't hurt either
Old Aug 3, 2012 | 08:02 PM
ACEkraut11's Avatar
ACEkraut11
If you use Simple Green make sure you dilute it or the run off will have the tint of your paint......ask me how I know.
A fireman's nozzle is a good idea as it gives you very good control regarding spray pattern and amount of water flow.
The procedure I use is to we lightly, coat with a cleaner, use a few soft brushes to loosen stubborn dirt, rinse gently, repeat as necessary.
I am not sure about the 2nd generation cars but the Body Control Module on the 1st generation models is sensitive to moisture. So excessive amounts of water, especially to the back side of the engine can produce excessive moisture which can provide some fun effects with electronics in the vehicle until things dry out. Again, ask me how I know.
Old Aug 3, 2012 | 08:50 PM
Dozuki01's Avatar
Dozuki01
It would be great if we can find a write from a member here for DYI. What to do, not to do and what to cover up properly.
Old Aug 3, 2012 | 11:04 PM
Fly'n Brick's Avatar
Fly'n Brick
I used simple green, diluted of course, on a dust rag to wipe down as far as possible then got underneath and wiped up as far as possible then used a long skinny brush to clean possible. Keeps from getting the wrong things wet. To get the bugs off the radiator behind the lower grill I use a refrigerator coil brush. Any appliance repairman can get you one for around $10.00. Once I got the engine bay good and clean the first time it is now much easier to maintain. Just the water blown under the bonnet from normal regular washing is sufficient to wipe down the engine bay and keep it looking impressive. Be careful of the paint under the bonnet, it is not clear coated and some solvents can have their way with it. You'll love the reaction of people when you show off ALL of your MINI.
Old Aug 5, 2012 | 01:52 PM
Capt_bj's Avatar
Capt_bj
If willing to invest a few dollars, what I use is a low cost steam cleaner
cuts grease and oil like a hot knife thru butter and doesn't toss as much water around
http://www.walmart.com/ip/Euro-Pro-S...ocket/16553554
http://www.walmart.com/ip/Mcculloch-...ndingMethod=rr
Old Aug 11, 2012 | 04:34 AM
MiniS2010's Avatar
MiniS2010
Thannnnks U every one
I will pist a PIC before and after :-)
USNAE2
16
Jun 17, 2022 07:17 AM
OutMotoring
Mar 3, 2017 06:29 AM
Colt45Magnus
Oct 1, 2015 04:08 PM
M7Speed
Oct 1, 2015 07:05 AM
mini merle
Sep 30, 2015 04:42 PM
