Suggestions on the proper way to clean the Power Steering Fan?
Old Apr 12, 2012 | 09:40 AM
matthew-w's Avatar
matthew-w
Hi,
I want to clean my power steering fan (06 MC), and wondered if someone has some specific advice on how to do this most effectively.
I've searched the forum and G and found a lot of info on the fan in general, but nothing specifically about the ideal method(s) to clean it.
Thank in advance.
Old Apr 13, 2012 | 10:40 PM
RJKimbell's Avatar
RJKimbell
Is it apart or still in the car? For a Fan I would think that a can of Air would work ok, not sure the point of cleaning a Fan but ok??!! What ever method you try post some feedback, I'm sure this would help someone else wanting to do the same thing!!
Old Apr 14, 2012 | 06:48 AM
matthew-w's Avatar
matthew-w
It's on the car at the moment. I was hoping to learn more about a cleaning procedure before pulling it off.
I've got a minor oil drip ahead of the fan that is creating a bit of a mess on the fan itself, which is why I posted the cleaning question originally.
The fan is spinning freely, there's just a bit of oil and dirt accumulation on and around the fan. At this point all I've done is spray a bit of Griot's engine cleaner around the area to remove the oil accumulation (not on the fan itself). Using a rag I wiped down the fan assembly. I flushed the fan with water, realizing that doing so might not be ideal.
Given the reality that some oil will surely have worked its way around the fan itself, I want to clean it properly and thoroughly sooner than later. Given that the blades are spinning well I'm not overly concerned, however.
Old Apr 14, 2012 | 11:12 PM
RJKimbell's Avatar
RJKimbell
In that case, with a mess like that you'll want something with a little more cleaning power...you might try a 50/50 Solution of Simple Green and Water in a spray bottle, once off the car you could spay on the Simple Green and then use a Toothbrush to clean the area.
Hope this helps!!
Etrain
16
Aug 5, 2024 04:37 AM
JPMontes3
Aug 23, 2015 01:26 AM
azntaiji
Aug 13, 2015 03:24 PM
minipopkart
Aug 13, 2015 05:22 AM
