Black Wow Streaking
Old Aug 30, 2011 | 09:40 PM
Ween's Avatar
Ween
Black Wow Streaking
I'm using a foam applicator pad and following the directions (pea-sized drop) but it seems like I can't prevent visible streaking on my fender flares. What am I doing wrong? Thanks!
Old Aug 31, 2011 | 12:11 AM
OctaneGuy's Avatar
OctaneGuy
Visible streaking? Are you talking about shiny areas that are standing out from less shiny areas? What you need to do is apply the BW to the plastic and let it absorb for several hours, or days. Then wash the car normally...the plastic will be black and matte..the way it's intended to be. I know it's contrary to most people's understanding of plastic trim products that are applied AFTER a wash, but BW is different because it absorbs into the plastic and what's on the surface is washed off.
Richard
Old Sep 1, 2011 | 09:23 PM
Ween's Avatar
Ween
Yes, areas that are shiny-er than others. Was not aware of applying BW *then* washing. Will give it a try; thanks, Richard!
Old Sep 1, 2011 | 09:38 PM
OctaneGuy's Avatar
OctaneGuy
Yep what you are seeing is normal behavior during the initial application. Seems more common on the R56 plastics which behave a little differently than the R50/R53.
Just be sure you give it ample time to absorb before you wash it...you want to wash off what didn't absorb, and not wash it off before it's had time to absorb..so plan to do the BW a day or longer before your wash.
Richard
Old Sep 2, 2011 | 04:53 AM
Reebus's Avatar
Reebus
Good info! I noticed the same thin after my first application of the product. I made the mistake of washing first and then applying the product. It looked as the original poster described the next day. I rained the next day, kind of cleaned it off for me,
and the trim looked great!
G1HQ
Dec 7, 2015 02:23 PM
honderpilot
Aug 24, 2015 09:25 PM
WayMotorWorks
Aug 4, 2015 01:47 PM
