Zaino Z2 or Z5 ???? Which one ????
Old Jan 31, 2004 | 12:48 PM
InfoSec's Avatar
InfoSec
Folks,
I am about to embark on my frist Zaino experience. I memorized the instructions sent with my package. I going all the way the with the clay bar first, I plan to use ZFX with either polish, but I don't know if to use Z2 or Z5. The color of my car is Indi Blue and the instructions on Z5 says it works great on clear coated dark colored cars. I know Z2 is intended for clear coated cars, but so is Z5!!!. I plan to use Z6 to finish off the first coat. I would love to hear the input of all you Zainophyles
Cheers :smile:
Old Jan 31, 2004 | 01:20 PM
Casey's Avatar
Casey
z5 is used to hide minor swirl marks and add depth to the look...z2 is what gives you the shine....typically what I'll do is do one coat of z5, one coat of half z5 and half z2 mixed up, and then the final coat of z2....then after that when I want to add more coats I add just z2. Use ZFX in with these and then use z6 between coats....always finish with a coat of z2 then z6.
Old Jan 31, 2004 | 01:23 PM
F15EWeapon's Avatar
F15EWeapon
easy question! Start with the Z5 for about 3 coats, then switch to the z2 for the top coat or 2. Always finish with the Z2, as it has higher optical properties and will really finish off the shine. If you are using ZFX, you will pretty much be able to get 4-5 coats on in a day if you have the car someplace warm and dry. If you are doing it out in the cold weather right now, bless you for your dedication! If it's less than 60 degrees in your work enviroment, give at least 3-4 hours cure time between coats.
Good directions are at http://www.zainobros.com
Old Jan 31, 2004 | 02:19 PM
Casey's Avatar
Casey
Zaino recommends doing any more then 3 coats in one day using zfx.
Old Jan 31, 2004 | 02:40 PM
Kiwi's Avatar
Kiwi
Just curious. I don't have my MINI yet, but plan on applying Zaino Z1 & Z2 (that I got for Christmas). Do you suggest before I start Z-ing, I should do the claybar first? Being that it's a new car, will I need to worry about wheither or not the dealer applied some-sort-of polish/wax to the car?
Old Jan 31, 2004 | 02:46 PM
asodestrom's Avatar
asodestrom
Yes, by all means begin with a claybar treatment. Nothing like starting wit a clean slate. The clabar is not only good for removing old wax, it's great for overspray, road grime, etc. It will make your finish smoother than a baby's behind. Do the glass also.
Old Jan 31, 2004 | 03:45 PM
Casey's Avatar
Casey
Since you have Z1 go ahead and use that...but for future purchases I would suggest using XFX instead of Z1. Z1 was what they originally came up with but since then they introduced ZFX which is an accelerator that you add to z2 and z5 and you don't need to use z1. When using z1 your drying times will be greatly increased. No worries the shine etc will still look amazing..but for future time savings use the zfx...it is spendy but you only use a couple drops per coat mixed in with the z2 or z5.
Additionally I would recommend reading http://www.zainostore.com/Merchant2/...p;Store_Code=Z
Old Jan 31, 2004 | 06:30 PM
InfoSec's Avatar
InfoSec
Cold ... what cold??? I am in South Florida perfect Zaino weather :smile: . But, I know what you mean, Thanks for the tip.
Old Jan 31, 2004 | 06:54 PM
C4's Avatar
C4
Been raining like crazy here! I have about 7 coats between Z5 and Z2 in my '04 MCS....1 more coat of Z2 coming up as soon as I get to wash the car next week.
Infosec: Where are you? In Miami or Ft Lauderdale?
Old Feb 1, 2004 | 07:42 AM
InfoSec's Avatar
InfoSec
I am actually in Pembroke Pines ... I know the weather Gods are conspiring against me in getting the car Zainoed. Hey but I can’t complain, I good be living up north with daily “it Sux to be you” sub-artic temperatures.
Cheers
Old Feb 11, 2004 | 09:34 PM
Scoutd's Avatar
Scoutd
I Zainoed for the first time last weekend, put 3 coats of z5 on. now to add to that wear do I start??
a wash with z7 and then I can start laying down the polish again?
Old Feb 12, 2004 | 05:04 PM
InfoSec's Avatar
InfoSec
That were I am at ... I got 3 coats of Z5 and this weekend I will start with the Z2. Just like you say. Wash with Z7 apply a coat of the gloss enhancer and put on the Z2+ZFX
Ryephile
Detailing 101
Sep 16, 2015 06:32 AM
Aqualung
Detailing 101
May 30, 2005 05:39 PM
Jerseygirl
Detailing 101
12
Mar 22, 2004 03:06 PM
vespa
Detailing 101
Mar 3, 2003 12:09 PM
