very thin clear coat scratch
Old Jan 25, 2011 | 12:03 AM
Shukie's Avatar
Shukie
It is probably around 1/5 mm thick and only visible from 3 feet away but I can still feel it a little bit if I go through it with my fingernail. I really want to fix it because it is like a foot long. Can I fix it with Scratch X or do I need to wet sand it? If I have to wet sand it, is there a way to buff out the dull wet sanded spot without a machine and which product should I use?
Old Jan 25, 2011 | 04:28 AM
Walt's Avatar
Walt
I would certainly give Scratch X 2.0 a try first.
Old Jan 25, 2011 | 01:03 PM
thulchatt's Avatar
thulchatt
Unless you have done wet sanding before you don't want to start with your MINI. It is difficult to do correctly and best left to a pro.
If you can't fix it with Scratch X you probably should seek a good detailer or painter (I have know many painters who wet sand not that repaint is the necessary solution).
Old Jan 25, 2011 | 04:56 PM
Shukie's Avatar
Shukie
I got it fixed with Scratch X today, and I also tried to remove some other existing contaminated areas with it but it didn't work... at least the scrach is gone.
Filmy
15
Jun 6, 2023 06:27 AM
Rainforest_Elf
Sep 16, 2015 10:13 AM
Ryephile
Detailing 101
Sep 16, 2015 06:32 AM
mikes603
Sep 11, 2015 11:00 AM
