Clay barring headlights
Old Dec 26, 2010 | 02:51 PM
steve20607's Avatar
steve20607
Santa dropped off some clear protective headlights film by the house. I will be doing more freeway driving so I want to lessen the impact(s) that certain objects could crack the lenses.
I want to make sure the headlight's surface is clean as possible. So can a clay bar be used on the plastic lenses without any scratching or side effects on them?
Old Dec 26, 2010 | 04:53 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Headlight lenses are plastic. I wouldn't try it.
Maybe some plastic polish or Plastic-X if you really need to spiffy it up some before the application.
Capt_bj's Avatar
Capt_bj
yes it can but I'd go a step farther and use toothpaste
Old Dec 26, 2010 | 08:52 PM
RJKimbell's Avatar
RJKimbell
Here's where I'd look for Glass/Plastic Cleaning and Protection!!
http://www.griotsgarage.com/category...ss+cleaning.do
Old Dec 27, 2010 | 05:56 AM
ZippyNH's Avatar
ZippyNH
I personally would use a headlight polishing kit...then apply the covers.
That way you have the cleanest, and the clearest lens possible...
Old Dec 27, 2010 | 09:15 AM
mini44's Avatar
mini44
That's a new one to me. What would it do?
Old Dec 27, 2010 | 02:43 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Some toothpaste is a mild abrasive, I think.
Old Dec 27, 2010 | 04:13 PM
daflake's Avatar
daflake
Old Dec 27, 2010 | 05:09 PM
Capt_bj's Avatar
Capt_bj
all toothpaste is nothing more than a mild abrasive in a supporting gel/paste with flavor
Search youtube for headlight cleaning and you'll find videos of folks clearing fogged lens with everything from quality rubbing compound to .... toothpaste.
I've polished out many a blemish with toothpaste ... an old guy trick from b4 the companies selling you the same thing under fancy names for 20 times the price!
Want your jewelry to sparkle? Take it into the shower with you and under the stream hit it with your old toothbrush and CREST or COLGATE ....
BLING!!!!
Don't believe .. well pay the $$ ... I'll continue to use Crest!
Old Dec 28, 2010 | 03:40 AM
daflake's Avatar
daflake
And your headlights won't have any cavities!
Actually toothpaste is a great product to use for stuff like this.
Old Dec 28, 2010 | 11:47 AM
JPMM's Avatar
JPMM
clayed the lights
I tried claying the headlights on our BMW, it made the plastic lenses silky smooth, but did not remove any pits . Did'nt hurt anything.
Old Dec 28, 2010 | 03:44 PM
Capt_bj's Avatar
Capt_bj
sure ... clay is about the equiv' of a 5000 grit sand paper ....
to get a pit out of something you need to remove some material and a 5000, nor even a 2000 grit ain't removing much per swipe . . .
removing a pit happens one of two ways .... you lower the surrounding surface until the 'pit' is no longer a depression .... or you fill the depression with something until it matches the level of the original material
rtk90
Aug 29, 2019 09:08 AM
tylewis
Sep 6, 2015 07:36 PM
Suspension Products
Sep 3, 2015 09:41 AM
