Clay bar the wheels?
Old May 29, 2010 | 12:50 PM
polepino's Avatar
polepino
Has anyone ever clay bar'ed their wheels? It seems like a natural progression if you are going to clay bar your car. Thoughts? Concerns? Experience? Yes/No?
Old May 29, 2010 | 01:12 PM
michele r53's Avatar
michele r53
That's a good question I've been debating it myself
Old May 29, 2010 | 06:30 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Due to the amount of deposits of brake dust which would end up in the bar. I would just keep one bar aside for wheels, one for the MINI's paint surface. keep their containers clearly marked.
Old May 29, 2010 | 06:52 PM
OctaneGuy's Avatar
OctaneGuy
Most definitely. In fact, the next time you drop your bar of clay, don't throw it away. Set it aside as a "wheel clay".
Richard
Old May 29, 2010 | 07:15 PM
michele r53
How good does it work. Also what do use for light scratches on painted and powdercoated rims
Old May 29, 2010 | 07:19 PM
OctaneGuy's Avatar
OctaneGuy
Depends on what you are trying to remove. It works great when removing contamination that can be removed with clay bar.
You can rub out or buff painted/powdercoated rims by hand or a small orbital buffer like a Metabo SXE400 polisher. Otherwise, not much else as gaining access is usually the hardest part on wheels.
Richard
Old May 29, 2010 | 07:26 PM
michele r53
What would u recommend for a wax or polish to get out the light scratches
Old May 29, 2010 | 07:32 PM
OctaneGuy's Avatar
OctaneGuy
Well a wax won't get out scratches because it just protects, unless you use a wax with fillers. Are you really that concerned with light scratches on your wheels? How did they get there in the first place? You're going to have to make sure you don't put them back in.
You can polish out very light scratches by hand using Prima Swirl.
http://www.showcarsupplies.com/shopexd.asp?id=69&bc=no
I normally wax my wheels with Prima Hydro because it's easy to do.
http://www.showcarsupplies.com/shopexd.asp?id=68&bc=no
Richard
Old May 29, 2010 | 07:44 PM
michele r53
Thanks. I'm a lil crazy theres a few light ones that are bothering me
Old May 30, 2010 | 08:41 AM
kenchan's Avatar
kenchan
i just use cleaner wax when wheels are THAT dirty.
Old May 30, 2010 | 10:17 AM
iwashmycar's Avatar
iwashmycar
when i clayed last i did the paint as usual, then all the glass, then the rims... worked good.!
Old May 31, 2010 | 08:16 AM
lotsie's Avatar
lotsie
Yes, I have thoughts about it. No concerns about doing it. Yes, I have done it for years to many kinds of wheels.
Aug 12, 2015 01:24 PM
nomar116
Aug 10, 2015 11:24 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
