Can anyone recommend Engine & Wheel Well Cleaner?
Old Aug 7, 2009 | 10:57 AM
kreative's Avatar
kreative
I'm looking for something to clean the engine bay as well as the undercarriage/wheel wells. Through some research, I've found the Meguiar's All Purpose Cleaner (APC), and Adam's Polishes has a similar product. Adam's also has some undercarriage spray. The other solution I've read it to use diluted Simple Green. It seems these should be applied using a boar's hair brush, so I'll probably have to get one of those as well. What about rinsing the engine bay with a water hose after application? Is it safe?
Anyone with any experience with these products give any insight or recommendations?
Old Aug 7, 2009 | 12:56 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Simple Green, let sit for minute then hose off.......when engine is cold btw....
Old Aug 7, 2009 | 02:00 PM
miniblucabrio's Avatar
miniblucabrio
for the engine itself try some CD-2 engine cleaner. you can find it at autozone. Some really good stuff.
Old Aug 7, 2009 | 02:19 PM
Crashton's Avatar
Crashton
I use a fairly weak dilution of Simple Green on the engine bay. For the past 5 years or so that is all I've used for engine cleaning. It has worked very well for me. Once done I spray the engine compartment with Griots undercarriage spray. When done the engine compartment looks new.
Old Aug 8, 2009 | 06:19 AM
phil@detailersdomain's Avatar
For engine cleaning these products listed here are solid
Engine cleaning and dressing
iggi
18
Feb 9, 2026 01:00 AM
Alkaidovich
Jan 30, 2021 01:35 AM
calebmil
Aug 7, 2015 05:54 AM
PatrikKN
Aug 5, 2015 09:10 PM
