DC Metro MINIs (Archive) The old DC Metro MINIs club forum, now closed. Visit their new forums at www.dcmetrominis.org/forums
The Transformation
Old Feb 19, 2007 | 03:24 PM
  #26
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
Old Feb 19, 2007 | 04:11 PM
  #27
Edge's Avatar
Edge
AdMINIstrator
821 lb/ft of Torque? Seems a bit... ridiculously inaccurate, considering that the Dodge Viper V10 produced from 490 to 560 lb/ft (depending on generation). Are you sure it's not supposed to be a different scale, like inch pounds? Unless of course we're supposed to view the 178 lb/ft number under "TorqFly", which makes more sense. Why wasn't that number graphed instead?
The HP numbers are awesome though - 223 - nice! Time to upgrade to wider tires.
Old Feb 19, 2007 | 04:25 PM
  #28
Maxicooper's Avatar
Maxicooper
It's time to find the way to put all the power to the ground.
Show us what "the Beast" is capable of.
Old Feb 19, 2007 | 04:44 PM
  #29
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
The torque figure in the graph is the wheel torque. The torque spec from the factory is crank torque. So the number in the graph is crank @ gear ratio. In this case it was run in 4th gear so it had a gear ratio of 4.615.
Old Feb 19, 2007 | 04:46 PM
  #30
Jeremy1026's Avatar
Jeremy1026
Moderator
That is the power on the ground...he needs to find where to unleash that power.
Old Feb 19, 2007 | 05:02 PM
  #31
Edge's Avatar
Edge
AdMINIstrator
Ah OK, makes sense... then the 178 number is the appropriate one for general comparisons. It's the scale that most people are used to seeing and talking about, anyway. Very impressive though, I didn't mean to discredit your ride... but you must agree that 821 crank would be... just a little bit nuts.
Old Feb 19, 2007 | 05:30 PM
  #32
Maxicooper's Avatar
Maxicooper
Not if you burn tires all the way through the rpm band.
If you don't have traction, power is useless.
Old Feb 20, 2007 | 04:27 AM
  #33
luckydoggarage's Avatar
luckydoggarage
Dyno Tech Day
The initial response after Matts post about the Viper underscores why I wanted to have a Tech session to explain just what is being measured and how. The torque numbers that are usually posted are corrected numbers of flywheel torque. Chassis dynos do NOT measure flywheel anything but rather WHEEL(hub) numbers. For example, if you take a 3000lb Mini and try to accelerate it to 60 mph in 7 seconds do you think you could do that with 150lbft of torque at the wheel? Obviously not. These tests were run in 4th gear which has an overall ratio of 4.615 and produced roughly 830lbft measured at the wheel. If we divide 830 by the overall ratio of 4.615 we get roughly 180lbft at the flywheel. One of the reasons that we don't use lower gears like 2nd or 3rd is that with their overall ratios being so high at 7.793 and 5.651 would overload the torque capability of the dyno.
This Dynapack dyno produces extremely accurate and repeatable numbers. This is the reason that we chose it as this capability is a key factor in being able to measure and tune an operating system as complex as the Mini.
If you have any interest in this subject, please plan to attend our Tech day on March 17th.
Old Feb 20, 2007 | 05:02 AM
  #34
JustJAY's Avatar
JustJAY
Good job on plugging the dyno event JB
Old Feb 23, 2007 | 06:25 PM
  #35
Scavenger's Avatar
Scavenger
Matt,
How's your gas mileage looking these days? Also, is the ECU still being fine tuned or is the current config the final?
Old Feb 23, 2007 | 06:52 PM
  #36
chows4us's Avatar
chows4us
Hey Matt
Nice work on your car. Something I would have loved to do.
Very nice
Old Feb 23, 2007 | 08:58 PM
  #37
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
Originally Posted by Scavenger
Matt,
If I drive normally my mileage is actually better by about 1-2 mpg.
Filmy
15
Jun 6, 2023 06:27 AM
AZ R53
GP Talk
15
Sep 22, 2015 06:17 PM
Chippawaguy
Aug 18, 2015 11:17 AM
flredmini
Aug 12, 2015 06:35 PM
wikedgolf
Off-Topic :: Autos
12
Jan 31, 2007 09:01 PM
