DC Metro MINIs (Archive) The old DC Metro MINIs club forum, now closed. Visit their new forums at www.dcmetrominis.org/forums
Where to get Run Flats?
Old Dec 8, 2006 | 01:42 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
I have something wrong with my passenger front Run-Flat, air is leaking from the sidewall :(. What places can handle them and will be able to get me a new tire asap?
Old Dec 8, 2006 | 01:46 PM
JustJAY's Avatar
JustJAY
If there is a puncture on the actual sidewall, no luck in patching that, it can't be done. It may be a leaking bead and that can be fixed by getting the tire place to put sealant on the tire/wheel.
If you need to replace a tire, you need to replace 2 tires i.e; both front or both rear. It is not recommend to replace only one tire because you will end up having uneven wear on the opposing tire and have allignment issues and be off balance.
Also, go to Tire Rack and do a install location search.
Old Dec 8, 2006 | 01:47 PM
oldtrojan66's Avatar
oldtrojan66
How old is your Mini? I thought everything was covered (except road hazard, etc)on the Mini for four years! I know wear would not be covered, but a sidewall sounds like a manufacturing fault. You can find run-flats lots of places, but I have had fun looking at tirerack.com You might try there.
Old Dec 9, 2006 | 03:54 AM
Wagnbat's Avatar
Wagnbat
Ditto. Take it to a dealer first if you can (not Tate!!!). No harm in letting them check it out and possibly fixing it for free.
Old Dec 9, 2006 | 08:52 AM
Revwillie's Avatar
Revwillie
It sounds like the leaking at the bead problem with the run flats. I got the impression from someone else that the dealer might not fix it under warranty. I need to find out for sure if MoS will or will not. My RFs only have 3k miles. What's the milage on yours Jeremy?
Old Dec 9, 2006 | 10:09 AM
JustJAY's Avatar
JustJAY
He is getting the tire replaced at a Goodyear dealer.
Old Dec 9, 2006 | 10:16 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
Give or take 54k assuming these are the factory tires...
Yep, $221 after install :( merry x-mas to my MINI, a new shoe.
Old Dec 9, 2006 | 05:59 PM
Winston03's Avatar
Winston03
I have 2 Goodyear RFs with 15k on them and one with 22k or so that I want to get rid of. I'll bring them if the location is south of DC and outside the beltway. No charge. I just want them out of the garage.
Old Dec 9, 2006 | 08:43 PM
Revwillie's Avatar
Revwillie
16s, right?
Old Dec 9, 2006 | 08:52 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
how much, it wouldnt hurt to have a few tires around just in case.
Old Dec 11, 2006 | 07:52 PM
HAPA's Avatar
HAPA
Hey Jeremy,
I have a brand new Dunlop OEM run flat tire 17" never mounted and still has the sale sticker on the tread. If you want it i'll let you have it for $100.00
Old Dec 11, 2006 | 07:53 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
Originally Posted by HAPA
Hey Jeremy,
i have 16" rims :( runnin in justacooper
Old Dec 11, 2006 | 07:58 PM
HAPA's Avatar
HAPA
Ahh oh well the offer still stands for anyone else.
I also have two of the same tires but worn but in good shape could probably use for messing around on track days that i would throw in too.
Old Dec 12, 2006 | 02:23 AM
Winston03's Avatar
Winston03
Let me get back to you on the rim size. No charge for the tires. I enjoy a good run once in a while, just as long as I don't have to go inside the Beltway, either one.
Old Dec 12, 2006 | 08:34 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
if they are 16's id love to help you get them out of your basement then . Im north of the beltway, so we could both have a little motoring adventure and meet in the middle somewhere.
Old Dec 12, 2006 | 12:03 PM
Sam's Avatar
Sam
goodyear run flats
If you still have the tires and they are 17's - I would be very interested
Old Dec 15, 2006 | 06:18 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
anything on the size of the tires?
khumpert
Nov 30, 2015 11:48 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
ltjpunk7
Sep 6, 2015 07:32 AM
TJANK
Aug 24, 2015 06:11 PM
jziran
Aug 24, 2015 04:50 PM
