Cooper (non S) Modifications specific to the MINI Cooper (R50).
An Intake Question
Old Oct 15, 2006 | 11:30 AM
ncteechur's Avatar
ncteechur
An Intake Question
I am considering a CAI for my MC. I understand why the CAI may provide a modest gain in performance. What I don't understand is from a design perspective, the CAI seems much less complicated than the stock filter/intake system on the MC. If that is the case, why didn't the designers simply provide the CAI intake in the first place? What is the benefit of the stock intake with the plastic box and the extra ductwork, etc.?
Old Oct 15, 2006 | 12:50 PM
OldRick's Avatar
OldRick
1) Noise. EU regulations on auto noise are very restrictive, and most of the humans find high-pitched intake noise annoying.
2) Cost. A paper filter traps more fine dust, extends engine life, and it is lower total cost for the manufacturer to simply replace a throwaway filter than to clean a permanent filter, when you consider the cost of labor.
Old Oct 16, 2006 | 03:18 PM
mini552's Avatar
mini552
Ditto the above, plus no manufacturer wants to rely on the avg. customer's ability to realize/remember/follow thru on cleaning/oiling a permanent filter. Finally, at least with respect to the current Cooper, there is little to nothing to be gained in power from CAI - some people like the additional sound (or noise depending on your perspective) & some don't
Old Oct 16, 2006 | 04:52 PM
ncteechur's Avatar
ncteechur
Water through CAI
Is the danger of getting water through an aftermarket intake higher than the stock? Or really no difference?
Old Oct 16, 2006 | 05:04 PM
scobib's Avatar
scobib
Not much difference, really... Although, the stock airbox will tend to provide a bit more protection, but not much. The pickup point for both is about the same place.
I'm running the aFe, and I really like it - sounds a bit more tame and refined than the Promini intake it replaced.
Old Oct 17, 2006 | 04:25 AM
FL_blue_MINI's Avatar
FL_blue_MINI
i know about the CAI and short-ram, but there is something else, it was like a "hot air intake", why would anyone want that?
and is it really worth it to get the intake, because the stock air box is getting the air from the grill, like cold air.
Old Oct 17, 2006 | 08:30 AM
ProfessorDave's Avatar
ProfessorDave
There are other threads on this topic, so feel free to search re: the CAI and HAI issue. I'm not convinced that a wall created with aluminum (and excellent conductor of heat) significantly reduces the performance of an intake. Both CAIs and HAIs offer greater surface area of filter and less restricted air flow. The placement of most aftermarket intakes is exactly where the air box was, so you get fresh air through the stock tube.
I've thought of adding a piece of tubing onto the end of the stock air tube to direct even more air to my K&N Typhoon. Anyone ever try this?
Old Oct 17, 2006 | 03:38 PM
ncteechur's Avatar
ncteechur
Coffee Can
I believe some had played around with the idea of placing a container of some sort around their intake (coffee can perhaps?) and running a duct to the coffee can making sure the cold air goes directly to the intake. Don't know if they tried it or not.
Old Feb 28, 2014 | 05:18 PM
MiniVelvet's Avatar
MiniVelvet
I would like to try! But the last post in this thread was from 7+ years ago...
W0TM8
Dec 19, 2019 07:50 AM
The_Kid
Aug 28, 2015 04:50 AM
maniacalmorgan
Aug 19, 2015 08:44 AM
massmini03
Aug 12, 2015 11:19 AM
jrezzo
Aug 9, 2015 10:32 PM
