Cooper (non S) Modifications specific to the MINI Cooper (R50).
Performance Gain
Old Oct 17, 2006 | 10:17 AM
  #26
xtremepsionic's Avatar
xtremepsionic
205/55/15 is the best diameter fit for the 15" stock rims, however, you're right at the minimum required width for a 205 tire (5.5" wide rim) I had a set of 205/50/15 slicks mounted on the holies and the sidewall was very much slanted outwards from the rim, that's why I went with a slightly smaller 195/55/15 summer tire instead, slightly smaller sidewall, less flex, and doesn't buldge out as much. 205 is wider, but I wonder if there is actually more grip with a 5.5" rim. Unless you're racing with these tires, I find 195/55/15 summer tires to be more than enough for street use. By that I mean I can go above highway speed on the on ramps, or 32-38mph in a normal 90 degree right corner on a street, personally I think that's enough grip for fun street driving.
Old Oct 17, 2006 | 10:58 AM
  #27
Ranzo's Avatar
Ranzo
I have a few more things to do before I start on the motor but I am contimplating on doing a 10K or more redline NA motor which WILL yield me 200 BHP
Wowzers! How are you going to do that? That sounds wicked!!!
Old Oct 17, 2006 | 11:04 AM
  #28
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
You do have various sizes to choose from to fit the holey rims.
Every tire size will have it's limitations on selection of tires.
Both 195/55-15 and 205/55-15 can work for street driving. The difference in traction and performance will come from the tire itself (tread design, rubber compound, etc).
Old Oct 17, 2006 | 01:59 PM
  #29
Thinker2112's Avatar
Thinker2112
I was debating the 205 vs 195 tires. It will be a little while before I need new ones. But the 195 is a better size for the 5.5 wheels, if all other tire variables remain the same?
Old Oct 21, 2006 | 11:04 AM
  #30
Jtrem's Avatar
Jtrem
haha this turned into a tire thread.
Old Oct 21, 2006 | 12:55 PM
  #31
amg6975's Avatar
amg6975
You could always get an R53 engine and tranny and stick it in a Cooper with a FMIC. That would be awesome.
Old Oct 21, 2006 | 12:59 PM
  #32
goin440's Avatar
goin440
more awesome than r53:
Dodge 2.0 swap, it exists, but no one is speaking.
xpunisherx
Nov 27, 2015 03:32 PM
Sep 2, 2015 12:55 PM
Sep 2, 2015 11:15 AM
Sep 1, 2015 04:39 PM
Aug 21, 2015 11:25 AM
