Cooper (non S) Modifications specific to the MINI Cooper (R50).
Would the MCS injectors be a performance upgrade for a MC?
Old Oct 1, 2005 | 07:54 AM
gmcdonnell's Avatar
gmcdonnell
Just curious - are the fuel injectors on the MCS the same or different than those on the MC? If not, one would assume the MCS injectors have a higher flow rate and might provide better performance for a MC with CAI, MTH software and other performance mods.
Old Mar 17, 2011 | 09:42 PM
Vollgas's Avatar
Vollgas
MCS injectors will not work on R50.
The wiring is different.
The injectors are different styles.
There is a thread for performace injectors for R50.
Old Mar 18, 2011 | 05:25 AM
xxTHIR13ENxx's Avatar
xxTHIR13ENxx
As stated above, the wiring is different, and there are other threads relating to this.
That being said, I have a set of used S injectors, and purchased adapters for the wiring; we'll see if they work by next week.
- Leo.
Old Mar 18, 2011 | 07:26 AM
Helix13mini's Avatar
Helix13mini
Even with a tune to go along with bigger injectors, you'd get precious little power.
Old Mar 18, 2011 | 10:50 AM
xxTHIR13ENxx
Well, from what I've read (and I could be wrong), the stock MC injectors run close to 100% if you're up in the 130-140hp range, right? So with the "regular" mods (intake, exhaust, etc) + cylinder head, camshaft, and tune, you'd be close to that 130-140 range... If that's the case, wouldn't upgrading to bigger injectos be a good idea, then?
Perhaps I'm just misinformed...?
iggi
18
Feb 9, 2026 01:00 AM
Teh
Aug 22, 2022 04:37 AM
Zettinger
Aug 25, 2015 04:04 PM
Aug 11, 2015 09:01 AM
