Cooper (non S) Modifications specific to the MINI Cooper (R50).
Auto gear shift in high revs
Old Jan 17, 2012 | 03:23 AM
metellica's Avatar
metellica
I own a Mini Cooper R50, 2004 make, 1.6 lt engine with automatic transmission.
The automatic transmission also has Sport mode and manual (+/-) modes.
Recently, I encounter problems with automatic shifting. It began to appear a month ago.
I put the gear in "D" and apply mild throttle. The car starts accelerating but gear shifts occur in high revs (4000+) although I apply mild throttle. Since the gear shifts occur at high revs, the car shakes/rocks during gear shifts. In the past, it used to shift around 2500-3000 rpms under mild throttle.
Additionally, when I step my foot off the gas, the car tends to instantly downshift and, as a result, the rpm increases and stays high until I come to a full stop. Till the car stops, it shakes back and forth, similar to the case during acceleration. I haven't experienced that before.
In order to resolve the problem, I had the "lifetime oil" of the tranny changed. It did not resolve the issue.
The car's fault memory is also checked, but, unfortunately, no fault code or clue about what is going on.
Which unit controls the gear shifts in automatic transmission? ECU? Tranny Internal Control Unit? Does anyone know that?
What else should we check or suspect?
Any ideas would be appreciated. I really need help in that.
Old Jan 21, 2012 | 08:37 PM
jlee924's Avatar
jlee924
It sounds like you need to have the adaptations reset for the transmission.
Old Jan 22, 2012 | 12:16 AM
metellica's Avatar
metellica
Maybe... But I do not know how to do that... Is there a post? Or can you provide me with a related post on how to do that?
Old Jan 22, 2012 | 07:44 AM
jlee924's Avatar
jlee924
As far as I know, you'll have to take it to your nearest Mini dealership to do it. They're going to have to hook up the car to their scanners and reset it from there.
Old Feb 5, 2012 | 04:15 AM
metellica's Avatar
metellica
I have the parameters reset yesterday.
It seems that this resolved the issue. But I will try a few more days to be sure that it is thoroughly resolved.
Thanks for the suggestions and help.
Old Oct 19, 2012 | 02:17 PM
imvitaliy's Avatar
imvitaliy
I'm having the same issue with my car's rpm going over 4000 when going from 50 - 70mph.
Did the issue go away after you did parameters reset at the dealer? I was reading couple other forums with similar issue. Some people are saying that it could be an indication that it's transmission belt slipping. http://www.mini2.com/forum/first-gen...ml#post3796598
Old Dec 4, 2012 | 03:38 PM
metellica's Avatar
metellica
I think that discussion is about CVTs. Mine is not a CVT.
The car is running fine till now, but it really annoys me not to know what had resolved my issue.
09R56
Nov 16, 2022 10:49 AM
theblackfalcon
Oct 11, 2015 09:49 AM
Aug 12, 2015 01:24 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
