Cooper (non S) Modifications specific to the MINI Cooper (R56).
Water Pump 2005 Mini
Old Nov 4, 2011 | 03:56 PM
Bumble B's Avatar
Bumble B
My 2005-510 was leaking coolant on the garage floor. Facing the engine the coolant was dripping from the right side. The shop replaced the thermostat which is on the right side for $300. They also say the water pump was showing minor signs of fluid leak and should be replaced. There has been no fluid leak on the garage floor from that side of the car. Replacement cost estimate: $850. I am questioning the water pump replacement. What do you think?
Old Nov 4, 2011 | 06:38 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Minor signs do not necessarily mean puddles on the floor.
Could be just whitish buildup at seam....Maybe have it done with other maintenance / service to cut labor costs ?
Did they even ask ya ?
Old Nov 4, 2011 | 08:27 PM
Bumble B's Avatar
Bumble B
rAvEn- Yes, they wanted me to replace the water pump for $850. My question is, 'Do I need to replace the water pump?"
Old Nov 7, 2011 | 12:10 PM
schatzy62's Avatar
schatzy62
Well as this is the forums for the 2nd Gen MINI's I.E. 2007 + you may get better help if you were to post in the 1st Gen Section
Old Nov 8, 2011 | 06:40 AM
ZippyNH's Avatar
ZippyNH
If you trust their opinion, yes.
it is likely they are refering to leaking around the weep holes, indicating a failing seal on the shaft.
nobody can realy tell you if it really needs to br checked without looking. The price seems kinda high....
Cereall
Sep 5, 2019 06:05 PM
KrisMiss
Jan 3, 2016 02:02 PM
mdutton11
14
Oct 26, 2015 01:47 PM
tr3y003
Oct 22, 2015 10:48 AM
kwijmbo
Aug 5, 2015 09:00 PM
