Cooper (non S) Modifications specific to the MINI Cooper (R50).
Intermittent misfire.. Help? Please.. New mini driver
Old Feb 8, 2011 | 03:59 PM
Shewbodmini's Avatar
Shewbodmini
Hello, I have recently purchased an 04 mini with 100,ooo kms. It is under dealer satisfaction warrantee, and they have fixed a number of things... New standard transmission, clutch, fuel injector and coil pack. I continue to have an intermittent misfire, not predictable in any way, but often in second gear while the engine is under load. The car is in the shop now and they are trying to get to the bottom of it, and have not been charging me for this work, as it is still under then satisfaction warrantee. I asked for a compression test, and they said that may be a next step and that a full tune up might be needed. They also suggested they might need to buy the car back from me, but I love it and since so much has been done, I don't want to give up.
Any thoughts?
Old Feb 8, 2011 | 05:11 PM
roymo's Avatar
roymo
Many years back, I had a similar unpredictable misfire in a brand new 2006 MCSC. The car would go weeks without any problems and then it would misfire twice in the same day. When the car had a misfire, it would go into "limp" mode and barely run. Turning the car off and on again would sometimes "fix" it. It was very frustrating because the dealer could never reproduce the problem. However, they did eventually decide it was the flywheel. They replaced the flywheel and I never had the problem again. Did the dealer replace the flywheel when working on the transmission and clutch?
Unfortunately, there are a lot of potential causes for sporadic random misfires, but once they have eliminated the more common ones, then you might suggest the flywheel as potential culprit.
Old Feb 8, 2011 | 05:18 PM
Shewbodmini
Thanks, I will ask about that :-)
bneer
Jul 15, 2019 04:41 PM
arf88
May 31, 2016 03:07 PM
minicoclub
Aug 25, 2015 09:07 AM
xpunisherx
Aug 10, 2015 10:50 PM
