Cooper S Gas Cap
If I recall correctly (it's been almost a year since I did it), I taped some fishing line to the plunger to help ease it (barely) up through the hole, then grabbed and pulled it the rest of the way through.
Unfortunately, my car ended up with a couple of small battle wounds (small dent and small paint chip. I am 99.9% sure the small dent was from wrestling the old gas pot out of the car
The Good, The Bad and the Ugly
Unfortunately, the painted plastic trim piece is not uniformly flush all the way around. 5-7 O'clock positions stick out a bit, and even with pushing evenly across the entire trim piece, I am unable to get it to budge any further.
In the second photo, you can see the small nick I created from a screwdriver that ripped through the masking tape. I also created a small dent, which was probably from wrestling the old assembly out. I will probably get it fixed at a paintless dent removal place down the road.
mrjolliff
Oct 9, 2015 05:55 AM
