Cooper (non S) Modifications specific to the MINI Cooper (R50).
more HAI info needed please
Old Jun 14, 2008 | 07:07 AM
andrewholmes's Avatar
andrewholmes
ok i have decided to put a HAI system on herman ( cooper non s ) So far i have removed the old air box and most of the old "scoop" plumbing. All that i have had time to do so far was to use old air hose that goes to the throt body and wanted to know what everyone else, if anything, was using instead?
My last question is this, once you remove the front little scope and then the flex hose between, how the heck does the second part ( i think its there to collect any water that comes in through the front )
thanx in advance
Old Jun 14, 2008 | 08:53 AM
AliceCooperWA's Avatar
AliceCooperWA
If you're going to go through the trouble, maybe rig up a box to block off the engine bay hot air. The intake is already in the corner.
By second part, do you mean the tube that goes from the valve cover to the intake tube?
Old Jun 14, 2008 | 10:18 AM
andrewholmes
not at all the same part. if you take the air scoop comming off the from rad cover, it bends 90 then goes into a fex tube, then into a solid plastic part again. its the second plastic i am trying to get off. unfortunatly i dont have a working camera to post pics
miniuy
Oct 7, 2016 12:09 PM
arf88
May 31, 2016 03:07 PM
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
minipopkart
Aug 13, 2015 05:22 AM
Alkaidovich
Aug 4, 2015 10:06 PM
