Cooper (non S) Modifications specific to the MINI Cooper (R50).
Engine Damper
Old May 2, 2008 | 08:19 AM
  #26
LJMurphman's Avatar
LJMurphman
Here's a picture of the bushing (?) that it sits on. One thing to add here is that I have never felt the hesitation from full stop that others have written about. The Mini was in the shop for a transmission replacement (under warranty! see: https://www.northamericanmotoring.co...14#post2204214 ) and I had a loaner Mini. ON this car the initial hesitation off the line was very obvious.
Murph
Old May 2, 2008 | 08:23 AM
  #27
tennis_man's Avatar
tennis_man
It is part of the engine mount/suspension system.
http://www.realoem.com/bmw/showparts...66&hg=22&fg=05
Old May 2, 2008 | 08:25 AM
  #28
ScottinBend's Avatar
ScottinBend
The black "pillow" is the engine mount. That doesn't need to be changed. Has nothing to do with limiting fore and aft movement. The bushings are part of the first two pic's. The two pronged bar is attached at either end to the parts that would be replaced with the new bushings. There is also a similiar part under the car that actually does the majority of the work of limiting the engine movement.
Old May 2, 2008 | 08:28 AM
  #29
LJMurphman's Avatar
LJMurphman
Brilliant. Thanks folks. So the followup question then is whether it makes sense to purchase an engine damper. From other pics it appears that I would have to remove this part of the suspension system in order to install a damper. ? ?
Murph
Old May 2, 2008 | 08:31 AM
  #30
ScottinBend
The TSW damper replaces the part in the first 2 pic's but the bushing replacement kit from Outmotoring.com replaces both the upper and lower bushings.
Old May 2, 2008 | 08:33 AM
  #31
LJMurphman's Avatar
LJMurphman
Thank you. Much obliged.
Old May 2, 2008 | 08:35 AM
  #32
ScottinBend
You will be amazed at the difference either one of these mods will make.
Old May 6, 2008 | 07:43 PM
  #33
big willa's Avatar
big willa
Tsw damper
I installed mine and love it. The only thing at idle inside the car the engine makes a medium pitched noise / vibration. I'm ok with that if that is normal? With the radio on you can't really here it. Thoughts...
ebowling
90
Aug 4, 2019 09:15 AM
bobbiemartin
Jan 20, 2016 05:28 PM
cw40342
Oct 6, 2015 05:07 PM
Aug 21, 2015 10:41 AM
Emnotek
Aug 13, 2015 05:47 PM
