Cooper (non S) Modifications specific to the MINI Cooper (R50).
VIP damper installed!!
Old Mar 8, 2008 | 12:29 PM
  #26
newbs49's Avatar
newbs49
rjtrout
Thanks for the info. I have an 06 GP. I'll check before I order. I don't want to drill if I don't have too.
Old Mar 8, 2008 | 09:21 PM
  #27
rjtrout2000's Avatar
rjtrout2000
Originally Posted by newbs49
rjtrout
For sure! I totally understand not wanting to drill anymore than you have to, especially in such a tight area and vital area to boot.
Lemme know what you find out!
Old Mar 9, 2008 | 06:25 AM
  #28
PGT's Avatar
PGT
rjtrout
you have to. the '06 models have an extra piece welded on the shock tower. You are drilling roughly a 3/8" hole down low on the tower. I sprayed mine with underbody coating once the bolt and washer was installed (in the wheel well...to prevent corrosion).
Old Mar 9, 2008 | 12:14 PM
  #29
newbs49's Avatar
newbs49
Thanks for the info PGT. Would you recommend this brkt instead of the lower inserts that Madness sells. I've used the lower's before and they worked pretty well. Thanks for any info you have.
Old Mar 9, 2008 | 03:56 PM
  #30
PGT's Avatar
PGT
looking at the pivot point of the motor, the lower mount is in the better spot, but nobody makes a damper for down there. I've got PU inserts for the lower mounts....we'll see how that does in combination with the VIP upper.
Old Mar 9, 2008 | 06:07 PM
  #31
newbs49's Avatar
newbs49
Thanks for the info. My 03 had the lowers, it will be interesting to see what you think with both.
Thanks again.
Old Mar 9, 2008 | 07:41 PM
  #32
ScottinBend's Avatar
ScottinBend
I want to keep my LoTF damper but was wondering if this kit from Outmotoring.com replaces the mounts that the VIP damper replaces. Anyone know for sure?
Old Mar 9, 2008 | 09:20 PM
  #33
AliceCooperWA's Avatar
AliceCooperWA
How much difference would changing the lower engine mounts and the tranny mounts make? I know removing the "play" from the upper one makes a big difference, but how much movement will persist without changing the lower one and tranny mount? by changing the mount, I mean adding poly or a damper...
Old Mar 11, 2008 | 12:43 PM
  #34
AstroBlackS's Avatar
AstroBlackS
From what I've heard, the lower mount is responsible for about 60% of the engine movement. When I switched mine out to poly, it made a huge difference. Honestly, not that much nvh.
Old Apr 18, 2008 | 02:07 AM
  #35
07BPB's Avatar
07BPB
I have an 06 MC, built october 2006. It has the two holes on the mount... then again i presume those are the holes we are talking about.
Old Apr 18, 2008 | 10:31 AM
  #36
rjtrout2000
That's them most likely!
Old Apr 18, 2008 | 04:17 PM
  #37
07BPB's Avatar
07BPB
Goodo. Now I need a damper to stick in there.
Old Apr 19, 2008 | 09:06 AM
  #38
rjtrout2000
The big reason I bought the VIP was the OEM look and the lack of NVH, which are both good things in my book. Other than that, I know TSW makes a damper that many people like as well.
Old Apr 19, 2008 | 09:26 AM
  #39
cucho's Avatar
cucho
Sorry for the dumb question...buy can any of you elaborate on the benefits of this mod...what is achived by doing it?.
Old Apr 19, 2008 | 09:37 AM
  #40
AstroBlackS
It helps to reduce engine movement, which in turn, allows the power transmitted through the engine/tranny, be delivered to the wheels more consistantly.
Old Apr 19, 2008 | 09:44 AM
  #41
cucho's Avatar
cucho
OK, makes sense...and at what point is recommended/needed?...I mean even an stock MCS would benefit or only a modified would?
Old Apr 20, 2008 | 05:47 PM
  #42
rjtrout2000
It should benefit stock and modified vehicles alike.
Old Apr 20, 2008 | 06:21 PM
  #43
wildfamily's Avatar
wildfamily
I installed mine on my 2006 MCS back in February. It was an easy install and works great. No vibration and the shifting, transmission of power from the engine to the wheels is down-right snappy. Inexpensive and well worth it!
adrchn
Aug 13, 2019 02:11 AM
silence2-38554
Nov 12, 2015 09:39 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Aug 21, 2015 10:41 AM
