Engine moving
#1 check the dogbone bushings on the right side of the motor (from driver position). Dogbone runs from block to firerwall mount by clutch line.
#2 check the motor mounts. One under the flywheel housing cover. One under the radiator mount.
#3 check other stabilser - you may have one from right front subframe to bottom lower right flywheel housing (under car)
I found deferent types of brackets
1- MOTOR / ENGINE MOUNT MINI COOPER - OEM
2- ENGINE MOUNT W/NUTS MINI COOPER
3- MOTOR MOUNT SIDE ENGINE MINI COOPER
My car engines STABILIZER RODS are ok, need to change the bushes only
What type of bushes I must have?
1- POLY STEADY BUSH KIT 4 BUSHES PLUS SLEEVE MINI & COOPER
2- HARD POLY STABILISER BUSH KIT MINI & MINI COOPER S
3- FULL RACE UPRATED STABILIZER BUSH KIT MINI & MINI COOPER
Ore if you recommend other types please list it
eatsleepautox
10-30-2015 06:46 AM
Colt45Magnus
08-12-2015 06:43 AM
