timing
Old Jun 12, 2006 | 05:19 PM
bigstick247's Avatar
bigstick247
timing
i have a rhd 83 1000cc mini and i have a miss when i drive i did put in new points new plus and wiers what is the correct timing?
Old Jun 12, 2006 | 05:25 PM
bigstick247
i am a bad typer i meant (plugs)
Old Jun 13, 2006 | 04:46 AM
OKeefe's Avatar
OKeefe
I'm 12 deg b4tdc
I have a 1275 Metro, with HIF-6 (1 & 3/4 inch) and a K&N cone. Stock cam and distrib', LCB
@ idle, warm, 1000 rpm and vacume line plugged I'm at 12 degrees before tdc.
Sorry - don't have my Haynes or my reference CD in front of me to check if that's reasonable for you or not. But I recently had a very good shop tune me and this was their recommendation.
Old Jun 13, 2006 | 06:52 AM
Jdewey's Avatar
Jdewey
timing
I have a 78 998, Australian.
The proper timing, was determined by putting the car on an exhaust gas monitor, and turning the distributor to the point that made it pass the pollution test!
John
Old Jun 13, 2006 | 08:27 AM
OKeefe's Avatar
OKeefe
Many say that's the only way to tune an SU!
John
Yep - many a web page says that's the only way to get peak performance from an SU, esp if you get into swapping needles: rolling road and an exhaust monitor. As well as saying to be sure your ignition is right on b4 messing with the fuel system.
btw - do you know what you're set at?
Old Jun 13, 2006 | 02:16 PM
Jdewey's Avatar
Jdewey
No I don't. I had it done by a shop that specializes in pollution work and had worked on other cars with SU carbs. I don't know which distributor is in the car. Some one removed the Vacume advance, and I don't know if they changed the advance wieghts or not. I picked up a distributor at the last swap meet, and plan to go through it and set it up right before my next pollution test in November.
John
Illinois.
Old Jun 14, 2006 | 05:51 AM
OKeefe's Avatar
OKeefe
Checked the owner's manual
I checked the Owner's Manual on CD from Heritage
for 69 to 75, 850 & 1000
850 @ 1000 rpm (vac disconnected) 11 deg btdc
1000 @ 1000 rpm (vac disconnected) 7 deg btdc
for 76 to 80
both @ 1000 rpm, vac discon', 7 degrees btdc
This is for a purely stock setup of course - factory spec dist' and plugs etc
I also cross checked to Haynes...
I consider it a starting point.
Old Jun 14, 2006 | 04:40 PM
bigstick247
thank you for your help it is much appreiated
Old Jun 15, 2006 | 07:00 PM
bigstick247
what should i set my points at?
Old Jun 16, 2006 | 07:32 AM
OKeefe's Avatar
OKeefe
Point Gap
According to the 76 to 85 workshop pubs per the Heritage CD
For the Lucas 45D4/59D4 dist' :
"Contact Breaker gap is .35 to .40mm; .48mm for a new contact breaker set to allow for bedding in of the contact breaker heel."
The .35 to .40mm is also provided in Haynes
Need dwell too?
That does differ by dist....
45D4 .. non-sliding contacts .. 51deg +/- 5
sliding contacts 57 +/- 5
59D4 54 +/- 5
bjcarter2
Aug 31, 2015 04:03 PM
Aug 12, 2015 01:24 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
wind715
Aug 11, 2015 07:56 AM
