amp guage
Old Feb 5, 2005 | 03:57 PM
STLMINI's Avatar
STLMINI
amp guage
hey all, i just got a smiths amp gauge for my mini. it's got two connectors on the back. while looking at the back they are at 9 o'clock and 3 o'clock. does anyone k now which should be the negative and which should be the positive?
thanks,
mike
Old Feb 6, 2005 | 11:19 AM
8ball's Avatar
8ball
I'm looking at the backs of two of 'em here and both have '+' and '-' embosed on the backs; They also are positive and negative reading (charging and discharging) so if you have one that has no indications on the back by the terminals, you can go ahead and hook it up either way - then observe the needle when the engine's running. If you think it's pointing the wrong way (showing a 'charge' when you think it's 'discharging'), just switch the leads ...
Old Feb 6, 2005 | 03:08 PM
STLMINI's Avatar
STLMINI
thanks 8ball.
Old Feb 19, 2005 | 03:29 PM
STLMINI's Avatar
STLMINI
ok, here's another question for ya... i ust got to installing the guage today. i took some wire and hooked one side to the ground and the other to a hot spot. once i turned on th engine, the wires heated up and started to melt. my buddy who was in the car said that meter read max +30. any ideas?
mike
Old Feb 19, 2005 | 07:20 PM
Minimad's Avatar
Minimad
http://www.ime.org.uk/ime/a/ammeters.html
Old Feb 20, 2005 | 11:19 AM
Jdewey's Avatar
Jdewey
electric meters
VOLT meters go from line to ground.
AMP meters go in line between the battery and the alternator.
Sounds like your amp meter was measuiring the amount of current your battery was capable of delivering to ground as limited by the size of the wires in the path.
Hope you did not burn to many wires.
John
Filmy
15
Jun 6, 2023 06:27 AM
Filmy
Apr 28, 2019 11:37 AM
Filmy
Sep 7, 2015 08:27 PM
jesterofatlas
Sep 4, 2015 11:23 PM
