Did I just buy bad shocks?
Old Jul 1, 2012 | 07:19 PM
TA2DMAC's Avatar
TA2DMAC
I just picked up a set of New non-adjustable front and rear KYB Shocks.
I'm not sure if they are supposed to be like this, but they are fully compressed.
I can pull them out with a little resistance and can push them back in until they bottom out. Is that normal?
I've never worked on this type of suspension so I'm a bit confused. Most shocks can't be compressed by hand and are usually fully extended.
Old Jul 1, 2012 | 07:49 PM
BRGPA's Avatar
BRGPA
I think you have a KYB "standard" hydraulic shock which can be extended and compressed with a bit of effort. The KYB Gas-Adjust shocks are different because the gas they contain forces them to extend, and it takes considerable pressure to compress them. I thought they might produce a harsher ride than my old tired shocks, but they do as advertised- produce a smooth, controlled ride and react quicky when things turn sporty. My guess is that your new shocks are fine.
Old Jul 1, 2012 | 08:18 PM
TA2DMAC's Avatar
TA2DMAC
Thank you, I was a bit worried for a moment.
Old Jul 1, 2012 | 09:57 PM
MiniMeep's Avatar
MiniMeep
I know ehow isn't the best source but: http://www.ehow.com/facts_7832402_di...ar-shocks.html
Also if they don't automatically extend then how are they going to work? they absorb shocks on the compression stroke and should fairly quickly return to an extended state ready to absorb the next shock.
They should take a fair bit of effort to compress, otherswise the approx 300kg per corner of the mini will make mince of it.
woodstudio
Mar 15, 2020 08:28 AM
Toolman
Jan 20, 2016 06:50 AM
06R53
Aug 26, 2015 08:37 AM
Emnotek
Aug 13, 2015 05:47 PM
nomar116
Aug 10, 2015 11:24 PM
