Bigger Wheels and Speedo Calibration
Old Aug 5, 2011 | 12:47 PM
prb44t's Avatar
prb44t
For those of you who have changed to 12 or 13 wheels how did you correct your speedo? Mine is now -5 or so MPH. Is there a new cable/gear that can be used to remedy?
Old Aug 7, 2011 | 07:58 AM
Capt_bj's Avatar
Capt_bj
well, I don't see anyone with a quick and easy solution
these guys say they can do it
Custom Calibrate Smiths and British Jaeger Speedometers as Required For Tire, Trans. and/or Gearing Changes
http://nisonger.com/index.htm
they advertise in many classic car mags like Classic Motorsports
in NY state
I've just learned what the conversion is and live with it as I'm thinking this won't be cheap. But since my odo' is also busted having the speedo' rebuilt is on my wish list for someday.
Old Aug 7, 2011 | 10:38 AM
jeffm5150's Avatar
jeffm5150
As far as I know, the only _real_ fix is to re-gear the speedo so that it is calibrated to the circumference of the wheel/tire combo.
For some reason I have speedometersolutions.com bookmarked. I think I was planning on getting an adapter to be able to run an aftermarket gauge with the stock Mini speedo cable, but ultimately decided to use the stock Smiths gauge. You might try to contact them and see what they can do for you.
And BTW, I have 12" wheels but the tire circumference is very close to the stock 10" tires, so my speedo is almost dead-nuts on. If your speedo is off then it's due to the tire circumference, not the wheel size. A smaller sidewall will fix that problem. I'm assuming you don't want to change tires to fix this issue.
Hope it helps,
Jeff
Old Aug 8, 2011 | 07:16 PM
prb44t's Avatar
prb44t
Thanks for the links and info. Might just deal with it for now. Have been considering a 1275/manual conversion from my 998/auto, so might Make more sense to wait since there isn't a plug n play solution.
I understand that overall diameter is really the key. When I switched from 10s to 13s I couldn't find a tire size that was close to the 175/65/10s. The typical 13" tires run on Minis have about a 1" bigger overall diameter. At least that I could find on the typical mini sites and golf cart tires stores.
Old Aug 8, 2011 | 08:21 PM
jeffm5150's Avatar
jeffm5150
Yes, sounds like a typical problem. Somehow my MIni's previous owner found some Yokohama 12" that are nearly identical to the 10" circumference. In the next 6 months I'm going to be in the market for some new sneakers and I will likely have the same problem that you do (although I won't be going with 13" wheels).
Let us know if you do come up with a solution and I'll do the same.
Old Aug 9, 2011 | 06:49 AM
kymummer's Avatar
kymummer
This thread makes me chuckle ... my speedo is in kilometers. I'm always running the math to approximate mph.
Old Aug 12, 2011 | 07:19 AM
joltfreak's Avatar
joltfreak
i'm using a GPS based speedo in my mini. no need to re-calibrate
kevinminict
Jun 3, 2016 01:31 PM
maniacalmorgan
38
Sep 29, 2015 04:56 AM
Herleman
Aug 16, 2015 06:41 PM
2manyhobbies
Aug 9, 2015 06:02 PM
jcb-memphis
Aug 8, 2015 11:09 AM
