Choke connections to single carb - need images
Old Oct 19, 2010 | 05:10 AM
womble's Avatar
womble
Hi folks. Had some work done on my car recently and went to start it the other day and the choke handle came way too far out. Upon further investigation, I discovered the choke cable detached from the carb (rotator cam?) and a stretched out spring coming through the firewall with the choke cable ( on the engine side). Not sure where the spring came from, unless it was between firewall and console. Anyway, I have reattached the choke as best as I can recall and it works, but would like to see some good closeups if anyone has some shots. The screw that holds the choke wire to the cam was attached to the dangling spring and I left the spring there after I reconnected the choke. Is there some sort of keeper that fits on the wire to prevent it from slipping out, or is it kept in place with pressure from the screw?
Old Oct 19, 2010 | 01:54 PM
womble's Avatar
womble
Old Oct 20, 2010 | 05:39 PM
jeffm5150's Avatar
jeffm5150
Here's a couple of close-ups of the carb linkage connection. It looks like the bottom of the screw tightens the wire into the hole and keeps everything together. My linkage moves freely and the wire doesn't slide inside the hole.
Hope it helps,
Jeff
Attached Thumbnails Choke connections to single carb - need images-carb_choke_linkage.jpg   Choke connections to single carb - need images-carb_linkage.jpg
Old Oct 21, 2010 | 02:08 PM
Capt_bj's Avatar
Capt_bj
I'm taking a guess here but I'll bet that somewhere along the life of this car the choke didn't release when the dash **** was pushed back in. So the owner added a spring at the choke on the carb to assist pulling the choke to off. And that spring broke or was broken by your mechanic.
There is a spring on the carb (choke shaft) that should perform this function. If it does not, try cleaning out the gunk and corrosion or if necessary replace the broken spring.
My guess anyway
p.s. there are many different 1 carb set ups . . . I've a single HIF-6 which looks close to the pictures posted . . .
Old Oct 21, 2010 | 02:49 PM
womble's Avatar
womble
That Capt!! Always an adventure under the hood.
Hippiehobbit267
Dec 3, 2019 04:22 PM
minimofo
Apr 4, 2016 07:36 PM
Chippawaguy
Off-Topic :: Autos
Aug 19, 2015 11:30 AM
bctf1
Aug 6, 2015 12:55 PM
OutMotoring
Aug 6, 2015 09:32 AM
