High Torque Gear Reduction Starters
Old Aug 12, 2010 | 02:00 PM
jeffm5150's Avatar
jeffm5150
Hey everyone --
My classic has one of the original non-pre-engaged starters. I see online resellers that have high-torque gear reduction starters for around $200. Are these truly bolt-on replacements or do you have to do any ring-gear mods? A friend told me that you have to flip the ring gear or some such thing.
Anyone have first-hand experience swapping one of these starters in place of a non-pre-engaged starter?
Thanks!
Jeff
Old Aug 12, 2010 | 08:31 PM
BRGPA's Avatar
BRGPA
When I installed my rebuilt 1275 the old starter gave a big Zap and died. I ordered a new gear reduction starter, and the installation was very straightforward. You can adjust its orientation with relative ease, and there were no issues with the ring gear at all. I must admit that I had a pre-engaged starter in the original setup, so I'm not 100% sure that it's a straight swap but I think it will work for you. I'm very happy with its performance- no issues at all. Hope this helps.
Old Aug 13, 2010 | 06:28 AM
Pflashinaz's Avatar
Pflashinaz
If you have a pre-engaged starter there should be no problems switching to a gear reduction starter. Clearance is an issue on some Minis with oil coolers.
If you have an inertia starter there could be issues with the ring gear as the bevel on the teeth of the gear are on the back side of the ring gear, the pre-engaged starter or gear reduction starter needs the bevel on the teeth on the front side of the ring gear.
Here's a good thread on the subject: http://www.minimania.com/web/threadi.../msgthread.cfm
09R56
Nov 16, 2022 10:49 AM
Markbett
Jul 3, 2016 04:28 PM
minipopkart
Aug 13, 2015 05:22 AM
Aug 12, 2015 01:24 PM
minipopkart
Aug 9, 2015 12:13 PM
