Guages
Old Jul 7, 2009 | 07:06 PM
  #26
yellowbritishrocket's Avatar
yellowbritishrocket
isnt there a mod you can do to put a larger output alternator in a mini?
Old Jul 8, 2009 | 01:03 PM
  #27
qskapunk's Avatar
qskapunk
http://www.adocars.com/elf-ado/alter...alternator.htm
Old Jul 8, 2009 | 01:09 PM
  #28
qskapunk's Avatar
qskapunk
very easy to do but you might need a slightly longer belt as the pulley might be slightly larger in diameter
just take your belt to an auto parts store and they can match it up with one thats a tad longer
Old Jul 8, 2009 | 01:11 PM
  #29
qskapunk's Avatar
qskapunk
Old Jul 8, 2009 | 02:21 PM
  #30
Capt_bj's Avatar
Capt_bj
Yes, we just had a long discussion about this not long ago.
the easist way to go - but not the least expensive - is to simply buy the alternator from a much later Mini which has higher output and is a direct bolt in replacement.
http://www.7ent.com/detail.cfm?pageid=2004
BUT - higher output does not mean you'll have juice at low RPM referring to the original issue. There you need an alt' made to produce full output at low RPM .... a special animal. It does mean you can power more goodies like 18 driving lites tho
{at low RPM you may see an AMP gauge bouncing .... that's cuz the alternator is just barely making juice....and will actually clip in and out as it's minimum is touched; or so I've been told by my resident mechanic advisor}
asmasm
Aug 18, 2016 09:34 PM
BRracing
Dec 22, 2015 09:25 AM
Bruce/Fl
Aug 28, 2015 11:59 AM
steebo777
How to
33
Oct 10, 2009 08:04 PM
Bahamabart
Apr 6, 2005 08:53 AM
