What would cause very little to no brake pressure?
So, as you guys know I've been working 73 1000, and next up is the brakes.
I currently had drums on the front and back, on 10" rims. The problem I am having is when I press down on the brakes when driving there is very little to no brake pressure......but once I let go the brakes, and pump them one more time.....it grabs like crazy. It just needs one pump and thats it to essentially lock up the brakes.
What would cause this? The master cylinder? It seems like the brake cylinders themselves are decent (as in they arent leaking), brake fluid is completely full, lines look good......
Any pointers?
Any pointers?
Any pointers?
Any pointers?
Make sure your drums have not been turned out too far creating too much travel for the system to take up. There is a max diameter, and its not hard to exceed it.
Make sure your shoes have enough lining left. Shoes are cheap.
After a good adjust, check again. If you press the pedal and it gradually sinks with constant pressure on it - you have a bad cylinder somewhere. If you press the pedal and it is low, then on second press is high & firm - it is adjustment/drums.
Interior/Exterior Unboxing Video of Sneed4Speed R53 Brake Cooling Kit
Gremothra
09-09-2015 08:42 PM
squawSkiBum
09-02-2015 09:56 PM
doug5g
09-02-2015 04:53 PM
