Questions for reassembling a roll-up window door
Old Feb 1, 2009 | 12:37 PM
OKMini's Avatar
OKMini
When I took my door apart, there was some gray sealer material between the roll-up door mechanism and the door sheet metal and it had gray cloth-type tape over many of the holes. (see attached pic).
I am wondering what type of materials to use when I put the doors together. I have found some "Gaffers tape' online that is cloth based but leaves no residue like duct tape. As far as the gray sealer goes, is this a general purpose 3M mastic?
Any thoughts?
The springs on my door regulators have some surface rust. Do these come out or does that turn into a real mess trying to reassemble? Should I use a steel wheel on a Dremel to clean it up? I assume white Lithium grease is best for the rollers and the gear teeth/springs on the regulator. The mechanism worked fine when I disassembled the car.
Thanks for any insight...
Old Feb 1, 2009 | 01:29 PM
Minimad's Avatar
Minimad
Attachment 39888
Any thoughts?
Duct tape is just fine.
Why not use Plumbers Putty for the grey sealer?
White Lithium is fine.
Don't know that I'd take the mechanism apart. Wire brush them? That's up to you.
Old Feb 2, 2009 | 02:18 PM
mk1leg's Avatar
mk1leg
Hi..Iused BLU-TAC wich is sold over here at a stationers does a bilriant job..........
woodstudio
Mar 15, 2020 08:28 AM
Dec 23, 2015 10:36 AM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
