Replacing choke cable - special process?
Old Aug 25, 2008 | 07:44 AM
ImagoX's Avatar
ImagoX
I was rooting around under the bonnet the other day and noticed that my choke cable's plastic insulation is worn through, exposing the metal cable inside.
In a rare display of forethought, I've decided to replace it BEFORE it actually fails me (stunning, I know - don't get used to it ) and I wonder if the replacement is straightforward, or if I'll need to yank off any unexpected engine parts to gain access to fittings. With my luck, Step 1 of the replacement will be "remove the entire engine from the front sub frame to expose the cable pass-through" or something silly... Hope not.
Thanks!
-Matt
Old Aug 25, 2008 | 09:29 AM
Capt_bj's Avatar
Capt_bj
problem I had with this repair was getting the right choke cable. Mine attaches to the dash with a screw fitting on the back side, but the one I got was sort of a plug into the dash thing, different ****...way different piece.... So I punted.
When you wore thru the plastic on the cable you exposed the metal wrap around the part of the cable that moves (there's what amounts to a flex' tube that the moving cable slides in...just like a bicycle brake cable). That's cosmetic. I released the cable at the carb end and slid some heat shrink tube over the worn spot with a couple of inches on either side. Heated it up and put it back together. Cost of repair, under a buck. Put on a couple of layers if you want, and build security. Or you can change colors....
btw - getting your fingers to the screw on the back of the dash fitting can be fun too....
Old Aug 25, 2008 | 10:33 AM
ImagoX's Avatar
ImagoX
Good point... the cable itself still seems solid. Maybe I'll just swap the wrap. Anyone know of a good metallic braided deal-io I can use?
Old Aug 29, 2008 | 10:11 AM
dimini's Avatar
dimini
ImagoX-
I like your humor/sarcasm on this. I'm beginning to see that these kinds of questions are probably very wise before attempting what might be misconstrued as a 45 minute task.
Old Aug 29, 2008 | 10:15 AM
Big Norm's Avatar
Big Norm
note to self: never "root around" ......
Old Aug 29, 2008 | 02:42 PM
Capt_bj's Avatar
Capt_bj
No other suggestions????
Well I'll try....
What I think you want is a metal type wrap/cover to slide over the choke cable?
Given the diameter of the choke cable you MIGHT get away with a braided fuel line. Worst case I'd think would be drilling out the end fittings but no promises. And I think a braided fitting this length might be a wee bit $$
I'm sure you can buy the braided line in bulk, but then you need to worry about end fittings so it doesn't unwrap.
Maybe go to a Harley store and see what fancy wraps they have for brake cables......it's basically the same cable.
Old Sep 6, 2008 | 04:24 PM
mk1leg's Avatar
mk1leg
If you guys are stuck for what to use, use a cable cover from a bicycle brake cable there the same dia well there the same over in England give it a try...............
thebordella
Aug 31, 2015 01:37 PM
Mini-Hype
Aug 17, 2015 06:32 AM
Emnotek
Aug 13, 2015 05:47 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
