carb to efi?
Old 07-07-2008, 08:31 PM
STLMINI's Avatar
STLMINI
STLMINI is offline
carb to efi?
Considering converting my 998cc from carb to efi. Anyone have any input?
Old 07-08-2008, 03:54 AM
Minimad's Avatar
Minimad
Minimad is offline
Uhm, why? What do you hope to accomplish by making the Mini more complicated?
I suppose you can buy someone's SPI take-off parts and refit. Saw some on Minimania or the Mini club in Vancouver....
Old 07-08-2008, 04:18 AM
Capt_bj's Avatar
Capt_bj
Capt_bj is offline
MiniWorld
MiniWorld, Summer 2008, pages 98 to 103
"Inject your Mini" using the Canems system .....
Old 07-08-2008, 05:59 AM
ImagoX's Avatar
ImagoX
ImagoX is offline
Assuming you have the diagnostic tools to figure out problems with the ECU, an injected Mini will probably be... well, hjust about as much trouble as a carbed Mini. I see lots of threads on the UK forums looking for help with diagnosing SPI and MPI issues, but reading them it seems like most of the issues come from a lack of the proper code readers and lack of knowlege of injected fuel systems. Do you feel comfortable working on and diagnosing such engines? If so, you can probably build a Mini with a hair more HP going injected, true. Still - I prefer the old, carbed Mini personally (although I do want to put in an electronic Petronix ignition to replace the old, mechanical points), but to each their own, right?
Old 07-08-2008, 06:28 PM
STLMINI's Avatar
STLMINI
STLMINI is offline
Minimad: Not sure if I want to or not. That's why I'm asking. I'm having trouble getting my Carb tuned correctly.
Everyone else: Thanks for the info.
Old 07-08-2008, 09:25 PM
msb2tg's Avatar
msb2tg
msb2tg is offline
dunno much about it as well, but have read maybe trying out megasquirt as an alternative.
Old 07-09-2008, 03:58 AM
Minimad's Avatar
Minimad
Minimad is offline
Just curious as to intent. SU carbs are much less complicated than most people think. You ought to be able to get it running right with a few changes. Once done, it should work well for a while. Do you have a Capstat (waxstat) SU? If so, I'd suggest converting it to the regular jet system as they are problematic and add issues. See www.joecurto.com for any SU carb part needs and advice.
Old 07-13-2008, 01:43 PM
Juiceman's Avatar
Juiceman
Juiceman is offline
Years ago I saw a mini with the bosch K jetronic mechanical fuel injection installed on his mini also a turbo. He got the fuel injection parts from a VW.
Old 07-13-2008, 02:28 PM
STLMINI's Avatar
STLMINI
STLMINI is offline
I've had the carb adjusted quite a bit and am still getting black plugs. With clean plugs the car runs great but after they foul it runs like crap.
Could anything else be causing the plugs to foul?
Old 07-13-2008, 04:46 PM
ImagoX's Avatar
ImagoX
ImagoX is offline
Do you have a Haynes book? If I recall, they do give a few other things to look for. Have you had the timing checked? Your choke can also be sticking, causing it to run rich - did you have to adjust your idle downwards when you had the carbs adjusted?
Old 07-13-2008, 06:18 PM
Capt_bj's Avatar
Capt_bj
Capt_bj is offline
Carb adjusted....
You say the carb has been adjusted....
has the needle ever been changed?
The needle is really the core to the performance of the SU, or so I've read in many places. And the 'true' method of tuning an engine with SU's is a handful of needles on a dyno and a gas analyser according to many sources.
or....finding a true SU expert. I was fortunate to live near Abacus Racing of Virginia Beach when I needed to sort mine out. Folks there identified my problem and improved performance literally within minutes of my pulling up to the garage door. Nothing beats an expert.
But back to needles....for example: if you pull the stock air cleaner system and put on a cone you need to change the needle....don't ask me which one it should be but usually checking with 7 or MiniMania provides a starting point. But just twisting the screws on the side of the carb won't cut it.
And...is it possible you are burning oil?
Old 07-13-2008, 07:38 PM
2phun's Avatar
2phun
2phun is offline
Mine's been doing the exact same thing.
Old 07-13-2008, 08:11 PM
joltfreak's Avatar
joltfreak
joltfreak is offline
are you getting enough spark? or running too rich?
Old 07-14-2008, 03:35 PM
Capt_bj's Avatar
Capt_bj
Capt_bj is offline
FIRST RULE - important
I really forgot an important rule - suggested by others here....
IGNITION SYSTEM FIRST....then fuel delivery.
If the ignition isn't spot on and you are messing with the carb you are most likely wasting your time. As I mentioned, Abacus found my problems within minutes....and the first was TIMING.
Be 110% sure of the ignition system first......
Old 07-14-2008, 03:52 PM
Dr Obnxs's Avatar
Dr Obnxs
Dr Obnxs is offline
Didn't do it on an old Mini
but did do it on an old Mustang... Got more power, better starting, and almost twice the gas mileage. FWIW, you don't have to replace with another stone age FI offering, you can go with modern stuff. There are aftermarket systems that aren't too expensive that will give you full access to fueling and timing without any fancy tools other than a lap top. I'm jonesing to do a Megasquirt project to an old Fiat I have with a two barrel webber.
Way I see it is if you're looking to make a driver a better driver, a good FI conversion should be at the top of the list. If you want to stay correct for collectability and authenticity, do what others here have suggested and get both the ignition and fueling working they way the should, and just learn to maintain them well.
Matt
IQRaceworks
51
10-10-2015 03:54 PM
bwirtz
08-29-2015 05:38 AM
Chippawaguy
Off-Topic :: Autos
08-19-2015 11:30 AM
JBravoMC
03-05-2007 07:36 AM
Agro
Classic Mini Talk
10-23-2006 07:28 PM
Quick Reply: carb to efi?
