Question about Tire Pressure
Old Mar 14, 2008 | 12:21 PM
bluella's Avatar
bluella
I have a Classic Mini 1979 year model with 175 50 13 tires on it and I don't know what tire pressure to run in them. I did get the owners manual on DVD and the service manuals but I don't think it has the tire pressure recommedation for that tire as it's probably an upgrade. They are Minilite wheels 13's of course... anyone have any ideas or knows what works best?
Thanks!
Old Mar 14, 2008 | 01:45 PM
womble's Avatar
womble
Tire pressure
I have same tires. 30-32 psi works well for me. Cheers, Tom
Old Mar 14, 2008 | 02:14 PM
shorn's Avatar
shorn
I've seen and read several places that either 28 all around or 28 in the front 26 in the rear. Haynes recommends 2.0 bar in the front, 1.8 bar in the rear for that size tyre. A bar = 14.5 psi.
Old Mar 14, 2008 | 03:10 PM
Rocan's Avatar
Rocan
28 seems a bit low to me. i think youd benefit more from 30-32
Old Mar 17, 2008 | 05:57 PM
chiquivw's Avatar
chiquivw
The way to go is 28psi front and 26psi the tha rear,do this when tires are cold , then take it for a ride and if you are going to change anything do it in 2psi. increments..this is what i did on my 199? sport pak and it's perfect ..
Old Mar 17, 2008 | 06:00 PM
Guest's Avatar
Guest
Thanks!
Tire pressure has a LOT more to do with the type of tire than what kind of car it is. Anything under 30 is going to have issues when it's wet out, and anything above 36 is going to have issues when it's hot out and you're driving hard.
As far as where the sweet spot is I couldn't tell you. I run my street tires at about 31 in the front and 33 in the rear, I run my race tires 1 PSI higher.
Old Mar 18, 2008 | 12:02 AM
MINIxB's Avatar
MINIxB
I run 30 in my tires.
Old Mar 18, 2008 | 10:38 AM
cube17576's Avatar
cube17576
Coordinator :: STLMini
The sidewall on my 165/60/12 Falken says max pressure is 35psi. So I run about 28 cold. So check the tire as well.
Old Mar 18, 2008 | 01:15 PM
bluella's Avatar
bluella
Thanks for all your ideas. I am currently running 30 in all four and will see how that does for a while. It's in the 70's here in Memphis, so it's not too cold. You guys are the best! Thanks again!
Old Mar 18, 2008 | 01:40 PM
dimini's Avatar
dimini
Are you bragging?
I'm so done with winter... Bring on the warmth.
Old Mar 18, 2008 | 10:06 PM
MINIxB's Avatar
MINIxB
Same here.
Old Mar 18, 2008 | 10:07 PM
Guest's Avatar
Guest
Most modern tires are 45-60 PSI max, 35 is very low.
Old Mar 18, 2008 | 10:31 PM
MINIxB's Avatar
MINIxB
Ummm our tires are smaller than most tires though...
Old Mar 19, 2008 | 07:51 AM
bluella's Avatar
bluella
Our tires are smaller... and they seem to be fine at 30... so far and sorry guys, not bragging about weather... that's just the way it is... of course today it is rainy and around 58 degrees...
Old Mar 19, 2008 | 10:07 AM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
The tires are smaller, but pressure is per square inch. Doesn't change with more square inches.
I usually run around 32psi on all 3 cars.
70 degrees? Brrr....it's gonna hit the low 80s today.
Old Mar 19, 2008 | 05:04 PM
Rocan's Avatar
Rocan
size doesnt matter... this reminds me of my BMX bike... i run 140PSi... high enough for you guys? =P
there must be tires rated over 35....
Old Apr 9, 2008 | 09:48 AM
mkbevington's Avatar
mkbevington
I like your Mini! It's very nice! Looks like it's in superb condition, too!
Old Apr 9, 2008 | 12:44 PM
bluella's Avatar
bluella
If you are talking about Ms. Sasha she is in pretty good condition, however, she's still a work in progress... Thanks!
Old May 6, 2008 | 12:15 PM
Usagee's Avatar
Usagee
My Achilles ATR Sports say 51 psi max. What are the draw-backs with running 42 psi?
Old May 6, 2008 | 12:42 PM
Le Fraug's Avatar
Le Fraug
I have 175/50-13s on my Mini and I run 30 in the front and 27.5 in the rear....
Old May 6, 2008 | 12:48 PM
ImagoX's Avatar
ImagoX
My 12" wheels are stamped 35psi max, and I generally fill them to 32 or so as I know they have slow leaks. The sidewalls don't have a rating molded into them?
Old May 11, 2008 | 02:46 PM
Rocan's Avatar
Rocan
they should make 12 inch (or even better 10 inch) run flats
Old May 11, 2008 | 11:15 PM
MINIxB's Avatar
MINIxB
From what I've heard about run flats they're a rough ride and combine that with a classic Mini you won't have any teeth left after driving around on some of the roads out here.
TJANK
Aug 24, 2015 06:11 PM
JamJam43087
Aug 16, 2015 02:02 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
nomar116
Aug 9, 2015 09:42 AM
