Headlights
Old Mar 2, 2008 | 05:40 PM
MINIxB's Avatar
MINIxB
Headlights
How hard is it to install new headlights on the classic? I'm planning on getting new ones for BB.
Old Mar 2, 2008 | 05:47 PM
Rocan's Avatar
Rocan
its not that bad. take a look at the ones on bumblebee and youll figure it out in a snap.
Old Mar 2, 2008 | 06:18 PM
Minimad's Avatar
Minimad
Buy halogen. You can get them anywhere.
Old Mar 2, 2008 | 06:48 PM
MINIxB's Avatar
MINIxB
Just the bulb or a whole new headlamp?
Old Mar 2, 2008 | 06:50 PM
stratman977's Avatar
stratman977
Mine is a wipac replacement headlight assembly so im not sure if it matches yours but if it does here's the steps.
1) Theres a screw on the bottom of the chrome ring, remove it and the ring will pop off
2) Underneath, theres about 6 screws but you only want to touch one of them. The one you want to remove goes directly into the plastic base and is not slotted (just a plain hole). On mine its towards the bottom. Do not loosen the screws that go into the slotted brackets. (The slotted ones keep your beam aimed)
3) The glass will come out of the base and then you can remove the 3 screws that clamp the glass to the inner ring.
Old Mar 2, 2008 | 06:51 PM
stratman977
You probably just need the bulb unless the plastic base is busted up.
Old Mar 2, 2008 | 06:52 PM
MINIxB's Avatar
MINIxB
I don't really need the whole new assembly i just need brighter headlights
Old Mar 2, 2008 | 06:55 PM
stratman977
I hate to say this but you probably will need to check out the wiring. Mine were dim and I cleaned connections to get them working better. I can't remember where the headlight wires hook into and my wiring harness is tangled up in a box so I can't help you there.
Old Mar 2, 2008 | 07:09 PM
Rocan's Avatar
Rocan
Personally i check everything every time i touch a section of a car. no point in having a new battery with frayed wires aye?
MINIxB's Avatar
MINIxB
they're really dim. i've heard of some mini's just having lights like this but i'll check the connections and hopefully i won't find rust behind the headlight...
Old Mar 2, 2008 | 07:52 PM
stratman977
Behind the headlight is the wheel well so you probably won't find any rust you didn't already know about.
I'd check the connector with a meter, you should have between 12 and 14 volts and a couple of amps at the headlight. That will at least give you a place to start.
You could also try hooking up the headlight directly to the battery to see if it gets any brighter, then you know if you need better bulbs or not. Just don't zap your self or start a fire doing this.
Old Mar 3, 2008 | 03:28 AM
joltfreak's Avatar
joltfreak
i switched to H4 bulbs on my mini and would never go back!
Old Mar 3, 2008 | 08:15 AM
H82WRK's Avatar
H82WRK
I have halogens on mine and they are a very nice improvement
Old Mar 3, 2008 | 11:49 AM
MINIxB's Avatar
MINIxB
What bulbs do I get?
Old Mar 3, 2008 | 02:58 PM
Rocan's Avatar
Rocan
bring in your old bulbs to autozone or pepboys and look around a bit.
Old Mar 3, 2008 | 06:44 PM
ImagoX's Avatar
ImagoX
Wait wait wait... If you upgrade the headlamps, you'll also need to be sure to upgrade the wiring.
As an example, let's take a look at these modern replacement lights from GBCarparts.com - a relatively common and inexpensive upgrade:
http://www.gbcarparts.com/proddetail...=Lamp7Headlamp
So, let's say you chose the "hyper white" xenon type bulbs, which are 100W per bulb. "Great!", you say. "That will be much clearer and brighter!" And you'll be right - these lamps can be expected to out something like 30%-40% more illumination than the dim, stock lamps (OEM, IIRC, is 55W main beam/60W high).
Here's the problem: 200W means that almost 17 amps of juice (16.666 to be exact) are flowing through the circuit, which is ALSO lots more than stock. Fine if you have the wiring to handle the load, but in the stock headlamp circuit, 100% of the voltage for the relatively dim bulbs is actually sent across the cabin switch - they are not wired with a relay like a sane person would do.
This is fine for the stock lamps, however this is simply more current than the switch or wires are built to handle,plus all that current is going through the plastic switch which you are touching with your possibly damp finger every time you turn on the lamps.
But wait.... it gets better.
In addition, there are many, many threads on the UK Mini forums talking about catastrophic MELTING of the switch and/or crisping of the wires after installing modern bulbs.Makes sense - the brighter bulbs would be sending about 70% more current through the wires and switch than they're safely rated to handle (approx. 17 amps instead of around 10 amps) - not good. To reiterate: fires under the bonnet or in the cabin are Officially Very Bad (tm) and should be avoided at all costs.
** Bottom line: if you do anything but replace the bulbs with OEM-rated replacements, you'll need to also install beefier wires for the actual lamps (10 gauge will safely tolerate 30 amps, which gives you a bit of overhead), a separate 25 amp fuse to handle the headlamp circuit (17A X 1.5 for overhead = 25A more or less), and I'd highly advise putting the headlamps on a proper relay, using the existing headlight wiring coming from the headlight controls on the steering column to control the relay trigger voltage. **
Or, if this freaks you out, you can simply trace every wire and clean everything up. Re-seating all the contacts is always a good idea, and MAY give you a bit more illumination - it can't hurt anyway. Be sure to disconnect the battery ground terminal before doing ANYTHING on the electrical system, and be sure to check every connection carefully. Any dodgy-looking splices (especially anything the previous owner did, likely wrapped in half-melted electrical tape) should be yanked out, replaced with a proper soldered connection and wrapped in a double-layer of heat-shrink tubing to make it water tight. Interior connections (not connections under the bonnet which can get wet) can be replaced with crimp-on butt-caps, available at Radio Shack for just a few bucks. Never use screw-on caps like you see in house wiring - the vibrations of the car walk them off, and once the wire is exposed it will short.
A butt cap - crimps on a pair of stripped wires, one in each end:
I'm doing this very same replacement later in the spring and I'll be sure to shoot pics for a How-to. I've run across several threads over the months (none of which I can find ATM), but another one can't hurt, right?
Old Mar 3, 2008 | 07:27 PM
Rocan's Avatar
Rocan
well said Imago. i think you summed it up.
WOOT!!!! 3RD GEAR!!!!
Old Mar 4, 2008 | 04:14 AM
Minimad's Avatar
Minimad
Std two lamp US headlights work without any wiring changes. They are available in halogen style at any parts store or even WalMArt.
But, first check your ground cable as this will also cause lights to dim. It is a group of black wires with an eye fitting attached to the firewall in the right front of the car in front of & below the Brake master cylinder. Remove the screw, clean corrosion and reinstall. Also check for corrosion at the lights. Remove the ring around the lights. Then remove the 3 screws holding the retaing ring around the lamp.
Old Mar 4, 2008 | 05:54 AM
MINIxB's Avatar
MINIxB
Matt, A how-to would be great. Especially with pictures.
Old Mar 4, 2008 | 10:56 AM
H82WRK's Avatar
H82WRK
I can take some photos of my headlights (on the car) if you would like. I do have the upgraded halogen bulbs but my wiring harness has also been replaced in whole. I did not think about that in regards to your Mini.
Old Mar 4, 2008 | 11:05 PM
joltfreak's Avatar
joltfreak
i used "angel eyes" headlights on my mini with H4 bulbs...i also have a new (homemade) harness on my mini as well
Old Mar 5, 2008 | 02:44 PM
Rocan's Avatar
Rocan
Sounds cool, got a pic?
Old Mar 5, 2008 | 03:03 PM
Capt_bj's Avatar
Capt_bj
Angel Eyes
I have 'em too
Running lite only:
RL and low beam
I have them on the standard harness (altho a new one...new wire but not heavier duty), not wired to a relay...(altho my big horns are to a relay and if I ever add driving/fogs they will be too)
http://minisport.com/acatalog/info_SPDWF-D6019.html
Old Mar 5, 2008 | 03:28 PM
Rocan's Avatar
Rocan
those look great! nice mini as well!
Old Mar 5, 2008 | 04:00 PM
H82WRK's Avatar
H82WRK
Turn the lights out! I want to see them in the dark!
