Headlights
Old Mar 5, 2008 | 04:20 PM
  #26
cbayles's Avatar
cbayles
Those angel eye lights are very nice! Minisport.com has a great catalog and their parts are relatively cheap BEFORE you add the shipping charges. I could spend so much money there.
My left headlight is out and the right one is very dim, but both high beams work ok. BTW, is the high beam lever just supposed to be momentary or should it lock in place when you activate the high beams?
Old Mar 5, 2008 | 04:26 PM
  #27
Capt_bj's Avatar
Capt_bj
In the dark
1. So the lites off in the dark....I should post a black frame?
2. Here's everything off but with ambient light
3. Depending on the year...yes, my stalk will 'clik' to a high beam position and stay...and has a high beam flash pull position. It's a 79 from that perspective.... (push to high beam..it stays. Pull to flash)
Old Mar 5, 2008 | 05:09 PM
  #28
Rocan's Avatar
Rocan
Those angel eyes add a lot of flare to a mini! im also guessing theres some insurance reduction because of the daytime running lamps?
Old Mar 5, 2008 | 05:42 PM
  #29
Capt_bj's Avatar
Capt_bj
Not DLR
They are not DLR....you could wire them that way I suppose but out of the box one usually wires to the running light position.
And, I've OC insured by American Collectors under standard collector car restrictions. I pay a few dollars per month. There's no DLR discount.
Old Mar 5, 2008 | 05:56 PM
  #30
Rocan's Avatar
Rocan
Still looks great
Old Mar 6, 2008 | 12:52 AM
  #31
joltfreak's Avatar
joltfreak
Old Mar 6, 2008 | 05:43 AM
  #32
H82WRK's Avatar
H82WRK
I am sorry you probably thought my request was wierd, I should have explained it better. It would be cool to see the lights in the nighttime (you know like turned on outside in the dark) Sorry!
Old Mar 6, 2008 | 01:57 PM
  #33
Capt_bj's Avatar
Capt_bj
Well slap my behind and call me....
Well I guess I had a duh moment ....
gotta wait for the sun to go down as I just backed into the garage so I could work on the port side tomorrow.
Stand by, sunset in 90 minutes
break
OK it is dark....cuz it is raining......I stood in the d'way and took a pik with the lites on.
2 spots of lite with black all around........
I'm done....
Old Mar 6, 2008 | 06:33 PM
  #34
Rocan's Avatar
Rocan
Originally Posted by joltfreak
I love that ride soooo much. thats what im going to do to mine. is that a vtec? if it is, then im doing that but with a dual charged A+
Old Mar 8, 2008 | 10:59 AM
  #35
2phun's Avatar
2phun
Turn the lights out! I want to see them in the dark!
Or minus the flash. I want to see just the rings too.
Old Mar 8, 2008 | 02:23 PM
  #36
Capt_bj's Avatar
Capt_bj
Oh alright....
but I need to put a couple of things back together first as I attacked some small bugaboos today
Old Mar 8, 2008 | 07:53 PM
  #37
2phun's Avatar
2phun
A couple of things = the entire front end and a wheel?
Old Mar 8, 2008 | 09:17 PM
  #38
Rocan's Avatar
Rocan
I think that he didnt read the instructions right
Old Mar 9, 2008 | 04:57 AM
  #39
Capt_bj's Avatar
Capt_bj
got ya
you don't remove this much to clean the wheel well?
Look close and note the attachment points for an FRG front clip. Mine is a 2 part....so the bonnet can still be removed sep'. It is not a flip, but a couple of clips, and a couple of screws and one multi-plug for the lites and the front clip comes off. Takes about 5 minutes. That's how my 79 sports a MK1 grill....
Makes it real easy to clean up, grease, check the brakes, touch up underside paint....bugaboos
Old Mar 9, 2008 | 08:35 AM
  #40
2phun's Avatar
2phun
Do you find your front has any additional rattles or squeaks with this setup? It sure would make cleaning the engine bay or working in there much easier. I'm almost sold on the idea, but scared about even more rattles. I'm guessing with the working bonnet, this is still a steel setup rather than fiberglass?
Old Mar 9, 2008 | 09:05 AM
  #41
2phun's Avatar
2phun
Yeah, this looks pretty sweet...
Old Mar 9, 2008 | 03:45 PM
  #42
Capt_bj's Avatar
Capt_bj
Glass
No this is glass, but two pieces. Does it rattle more? My exhaust is so loud, and I have so many other rattles it's hard to tell! I dunno, I'm not the engineer .... I bought it like this. The bonnet piece rattled for a while but last year I added some self stick weather strip at the back edge and that holds it pretty tight against the clevis pins now. The ends held with rubber toggles are pretty tight. The bonnet isn't 'functional', that is it is not on hinges. It attaches with two race pins at the back and two rubber toggles up front. It comes off....see the sig pic...I put it on the roof. It weights a couple of pounds. The fender section is one piece, two race pins face forward on the front sill; two rubber toggles at each A panel, and since I have a large set or arches, two screws on each arch that go into the A panel. And one screw at the top, on the 'inside', about where the bonnet hinges would be. I use nylon screws with big wing nuts on the back. The electrics are tied into a big trailer type plug.
Pull it off and you can easily hug the engine, snuggle the brakes, and peruse all sides of the radiator. But the loss of inner fenders makes me even more paranoid about rain. Snow well, I live in Florida....it's in the mid 70's today. Eat your heart out you folks in Cleveland. Snow is cool but DAMN.
Old Mar 9, 2008 | 07:03 PM
  #43
joltfreak's Avatar
joltfreak
Thanks! I went with a 1310 A+ topped with a ported & polished head (between stage 2 & 3), Kent 266 cam, etc..... check out my mini page for more pics & info (http://joltfreak.tripod.com//id5.html)
Old Mar 9, 2008 | 07:34 PM
  #44
Rocan's Avatar
Rocan
Very nice. i gotta ask about the windscreen though... is it intentional? I love the flush doors, you should do a no handled electric unlock. Thats exactly the style im aiming for!
Scratch that... read your site- you did do the pop lock! now i love you even more
Old Mar 10, 2008 | 07:18 PM
  #45
joltfreak's Avatar
joltfreak
i got a front windscreen on it now and i'm debating going with a removable lexan rear screen, so i would have better access to the back....we'll see
OutMotoring
Mar 3, 2017 06:29 AM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
