gas
Old Sep 1, 2007 | 07:18 PM
ocminifan's Avatar
ocminifan
gas
i just filled up my new mini for the 1st time today. i am using supreme but i was wondering if any addatives are needed... do you guys just run on supreme or do you do something different?
Old Sep 1, 2007 | 07:22 PM
MINIxB's Avatar
MINIxB
My Mini runs on unleaded with nothing added. If yours has a new head on it, it can run unleaded. If it seems like it's running weird (sputtering, etc) it might be because you need to add a lead additive. I'd see what some of the more Mini experts say about this though.
Old Sep 1, 2007 | 07:26 PM
ocminifan's Avatar
ocminifan
i dont know if a little more info might help... well it is a 1961 1275 if that makes any difference...
Old Sep 1, 2007 | 07:28 PM
oldsbear's Avatar
oldsbear
I follow the manual and use the highest grade available. Around here that's 91 octane. I also follow Mini's recommendation to use "Top Tier" gasolines, as listed at http://www.toptiergas.com/ I figure the people who built the car probably know better than I what it needs, so I go with their instructions.
Old Sep 1, 2007 | 07:41 PM
MINIxB's Avatar
MINIxB
you might have to put lead additive in it.
Old Sep 1, 2007 | 07:59 PM
Madoc's Avatar
Madoc
I put a lead additive in my '73 998. My local expert says that it's probably not needed since I don't do much sustaned high speed driving. It makes me feel better, though.
Old Sep 1, 2007 | 08:06 PM
Miniranda's Avatar
Miniranda
Using premium gas in a lower compression naturally aspirated engine can make the fuel to oxygen ration to rich and cause premature ware. Consult the manual. I believe some Minis prior to 1989 were manufactured from cast iron and should be run on leaded fuel only; otherwise you can burn out the valve seats.
Old Sep 1, 2007 | 08:56 PM
lhoboy's Avatar
lhoboy
Do you have the history on the car. For example, has the head been rebuilt recently. If not, having hardened valve seats installed will be your best investment to avoid the need to blend with lead substitutes like Valvetect. If you don't have hardened valve seats yet and you don't use a lead substitute additive, you will be paying for a valve job shortly.
Old Sep 2, 2007 | 12:58 PM
MINIxB's Avatar
MINIxB
He's got a classic mini. not the same as the new ones.
Old Sep 2, 2007 | 05:58 PM
oldsbear's Avatar
oldsbear
Sorry. I was (and am) clueless.
Old Sep 2, 2007 | 07:19 PM
MINIxB's Avatar
MINIxB
It's alright.
Old Sep 2, 2007 | 09:02 PM
elprofe's Avatar
elprofe
premium
Old Sep 3, 2007 | 05:41 AM
Capt_bj's Avatar
Capt_bj
Ran midgrade once
I ran midgrade in my 1275 with 'unleaded head' once
once
never again. Hi test ever since.....
oh ya .... there was a difference
scfiveo
Sep 27, 2019 02:27 PM
PsychoRallye
21
Feb 17, 2019 06:08 AM
OutMotoring
Mar 3, 2017 06:29 AM
riff42
Sep 22, 2015 03:07 PM
mini_mike237
Sep 21, 2015 08:42 AM
