4th Generation MINIs Discuss the new EV Hardtop and ICE Hardtop models here.
ICE wiper blade size on 2025 F66
Old Nov 28, 2024 | 05:47 AM
JayGee's Avatar
JayGee
I'm noticing a bunch of dragged/loud wiping happening and hoping I can fit in the PIAA silicon blades. Anyone know what sizes this model uses?
Old Nov 29, 2024 | 10:05 AM
Hello,
This is the Genuine MINI set.
https://www.ecstuning.com/Search/Sit...h/61615A79741/
Historically MINI has uses 19" on one side and 18". It looks like they changed to a beam style VS the older Denso style on the F56 MINIs
Those should fit but i dont have a set of Genuine MINI wiper here for F66+ to compare.
Piaa 18/19" combo.
https://www.ecstuning.com/b-piaa-par...s-set/97048kt/
Let me know what yours measure
BTW the rear is this wiper blade: https://www.ecstuning.com/Search/Sit...h/61615A404F6/
Old Nov 30, 2024 | 02:23 AM
JayGee's Avatar
JayGee
Awesome! Thanks so much
Old Dec 2, 2024 | 08:25 AM
You are welcome!
Old Feb 5, 2025 | 02:26 PM
JayGee's Avatar
JayGee
Just an update, I randomly found an old set of piaa 18"+19" in my closet and quickly discovered that the sizes are not the same and the stalk connection is also different. The sizes I measured for the F66 are 20" (driver) and 21" (passenger). The connection bracket is wider than what's provided in the piaa set and has a little square cutout that you push to release.
Would know if the oem set that you sell is 20"+21" https://www.ecstuning.com/b-genuine-...s/61615a79741/
Old Feb 6, 2025 | 08:14 AM
Yep its the same size as the F66 factory ones you took off. It does not tell me the size, i dont have a set in stock to measure.
I bet its the same as the ones you took off. They are those valeo ultra flat beam design from what i see. No aftermarkets yet. Valeo has not released a package kit. Post up pictures of your old ones.
New 2025 MINI® Cooper S at Jackie Cooper BMW MINI | Cooper Auto Group
Old Feb 9, 2025 | 03:13 AM
JayGee's Avatar
JayGee
Thanks for the info and here are some pics.
Old Feb 10, 2025 | 08:21 AM
Ok thanks, now i know the connection type. The genuine is the same size and design as the ones you have and would be the same length.
The universal ones would have to have that connection.
Looks like the R58 and R59 MINIs ( i have a R58) share the same size and set up. And the piaa have that connection.
https://www.ecstuning.com/b-piaa-par.../9705097053kt/
Old Feb 10, 2025 | 09:05 AM
JayGee's Avatar
JayGee
Awesome! Thanks for your help
Old Feb 10, 2025 | 09:21 AM
Yep, let me know and i can add them to the catalog for that fitment. Based off what i see it should work. All the aftermarket companies i work with dont even show any cross fit with that Genuine MINI part yet so we are in new territory.
Old Feb 19, 2025 | 03:15 PM
JayGee's Avatar
JayGee
Unfortunately the PIAA adapters don't fit. They come close and perhaps with some modification they could work, but not as is. The OEM set does work, which is good but I generally prefer the PIAA blades. Oh well, perhaps in the future they will add an additional adapter. Thanks again!
Old Feb 20, 2025 | 07:47 AM
Yep, send me a picture. I want to see if it can be modded or changed.
ssoliman
Feb 15, 2022 05:37 PM
mr_r56
Mar 14, 2020 04:49 PM
dubsdj
Mar 4, 2008 07:41 PM
holdenontoit
Jan 7, 2006 08:37 AM
Mini2Go
Mar 5, 2003 09:58 AM
