2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 DINAN Elite thoughts
Old May 28, 2019 | 05:20 PM
  #26
1RavingLunatic's Avatar
1RavingLunatic
Originally Posted by f60jcw
After installing the new Dinan, I'm assuming you didn't reinstall the intake and everything is fine?
Going on the above assumption, my thought - just thinking here - is that (based on your description of the temps when the problem was happening) - perhaps the combination of Dinan, with the intake with theoretically more volume of air (CFM) is fine for temps above 40F. Below 40F, the air is cooler (denser). So perhaps the increased boost created by the Dinan tricking the ECU plus the colder/denser air from the intake somehow pushes into a range that the ECU doesn't like and thus throws an over-boost code. This tells me the Dinan for some reason didn't take this condition into consideration and adjust accordingly.
A good test (though you might not want to bother with doing) would be to put the intake back in with the new Dinan when the temps drop back down to 40F and see if the problem comes back. If it does, take it about and revert back to stock...do the codes come back?
I'm definitely not looking forward to this happening to me down the line.
returned the intake. But I came up with the exact same conclusion that you did. If I didn't have to buy another intake, I would reinstall it. I might throw a K&N drop in. The intake doesn't do anything anyway, sounds nice though.
Old Jun 23, 2019 | 08:16 AM
  #27
Brookz's Avatar
Brookz
Any updates on the MPG thus far?
Old Jun 23, 2019 | 08:23 AM
  #28
F56-JCDub's Avatar
F56-JCDub
TL;DR: So far, I'm getting 1mpg less than before with the Dinan Elite installed.
I am attributing it to my lead foot. With the increase in available power, I tend to step on it more, because it is fun, especially paired with the JCW Pro exhaust. I'm sure if I drive more conservatively (which is hard to do), the mpg would definitely go up.
Old Jul 5, 2019 | 04:16 PM
  #29
Jamel DeCasseres's Avatar
Jamel DeCasseres
I just installed the Elite on my 2017 Countryman S and love it! Immediately noticed gains in normal mode and smooth accelerations. The gear shifts are shorter and definitely more pleasant. I've tried Sport mode maybe 3 times in short highway runs and its pretty good also. Only had it a week with the tune, but plan to share more as I get more miles in.
My question is - Has anyone installed the Elite on a Countryman S, then did the JCW Exhaust upgrade and Tune afterwards? If so, please share your experiences. I'm curious to know if there are any noticeable gains in doing so.
Old Dec 9, 2019 | 05:12 AM
  #30
MiniAdv's Avatar
MiniAdv
I have been using the Dinan Elite on my 2018 Countryman S All4 for past few months. Also added the NM exhaust system. Elite needed dealer to clear codes after install as my code reader could not handle full reset. Elite works great! Nice boost in power in Mid-Balanced and Sport Modes. Expensive, but worth the money.
Old Dec 10, 2019 | 05:50 AM
  #31
JDWatts's Avatar
JDWatts
How do you like the NM exhaust? Any drone issues?
Old Dec 11, 2019 | 08:50 AM
  #32
BTDUBS's Avatar
BTDUBS
I came here to ask that question since I have the JCW Tune Kit, which I highly recommend.
Old Dec 11, 2019 | 11:31 AM
  #33
ND40oz's Avatar
ND40oz
Because the JCW Tune updates all of the tables, it theoretically gives you more headroom for piggyback tunes. With the original Elite, Dinan used to show the differences between the BMWs with and without the M Performance tunes with the M Performance versions making more power and torque throughout the rev range. But since they've switched over to the Elite V2 versions all of those old graphs are no longer on their website.
Old Dec 12, 2019 | 07:09 PM
  #34
ny_yankee's Avatar
ny_yankee
Would anybody know if the elite for the JCW would work on the "S"? (2019) I mean it's the same plugs but the elite ECU is different.
Old Dec 15, 2019 | 07:26 PM
  #35
MiniAdv's Avatar
MiniAdv
No drone issues at all. Sounds excellent. Love it!
MikeMJCW
Jul 15, 2019 01:47 PM
tc1728
Jun 19, 2019 12:11 PM
2017All4
Jun 2, 2018 05:54 AM
DarkMiniCooperS
Aug 15, 2017 10:10 AM
SS Mini
Sep 8, 2006 11:07 AM
