R60 9CC2 Attention Electronics on the right headlight (SMC) reports errors
Old Feb 5, 2025 | 04:21 PM
anaustin's Avatar
anaustin
I have a 2012 Countryman S ALL4, 120,000 miles. It has xenon adaptive headlights (AHL). I'm intermittently getting an error with the headlights. The dash displays Adaptive Headlights error. BimmerLink reports an active error in the Driver's side footwell module, 9CC2 Attention Electronics on the right headlight (SMC) reports errors. My right headlight is original.
Has anyone received and resolved this error? I don't want to unnecessarily spend $300+ for a control module if the problem is elsewhere.
Thank You
Old Feb 10, 2025 | 04:07 AM
BlazingE60's Avatar
BlazingE60
I would start with removing the footwell module and closely inspecting all connectors and pins for corrosion, especially if you have the optional sunroof.
Old Feb 10, 2025 | 07:29 AM
anaustin's Avatar
anaustin
Good suggestion. I have a sunroof. I'll inspect both the footwell module and the headlight module for corrosion or bad solder joints and report back.
Old Mar 24, 2025 | 08:25 AM
anaustin's Avatar
anaustin
I apologize for not sending an update earlier. I pulled the footwell module and inspected its connectors. Everything was dry and clean.
Then I pulled the right headlight. I inspected the harness connection, the xenon control unit and the corning light control unit. Everything was clean and dry. I didn't see any burnt components, bent pins, or solder cracks.
The codes were coming every day in January, but I haven't seen them in a while. I'm curious if Spring's warmer weather is a factor.
Old Aug 15, 2025 | 08:25 AM
anaustin's Avatar
anaustin
RESOLVED
It's been a few months, but I thought I would follow up on this post. Problem resolved after I replaced "Headlight, Control Unit, Cornering Light, Right", part number 63127199362. The module is a little, expensive circuit board but far less than replacing the entire headlight.
Rogers90
Jun 15, 2022 05:45 PM
drone46
Apr 21, 2020 07:20 AM
troylees
Dec 5, 2013 10:49 AM
peekinde
Electrical
Nov 11, 2007 03:21 PM
