R60 replacement connector plug source
Old Dec 24, 2023 | 10:25 PM
JoeTho's Avatar
JoeTho
I just replaced my 2013 R60 thermostat and accidentally crushed one of the connector plugs when bolting the new one on. Checking my usual sources draws a blank- where can I order just the connector itself to solder onto the old wire? This is a two conductor oval connector, by the way.
The old connector got crushed and I need a new one- and the pinout diagram for this would be great too, if anybody has any ideas...?
Old Dec 26, 2023 | 09:17 AM
Does your MINI have piggyback upgraded harness needed? Do you have the last seven of the vin?
https://www.ecstuning.com/Search/Sit...h/12518611289/
Old Dec 26, 2023 | 11:37 AM
JoeTho's Avatar
JoeTho
No upgraded harness needed, I don't think. The replacement thermostat/housing I bought is a near exact duplicate of the one that was there to start with, -I just crushed one of the plugs (the one that goes into the cable jack controlling the map thermostat heater, I believe) and I just need that plug, to solder onto the existing wire. Where can I find a new plug (or plug with pigtail) like it? 2013 Countryman S all4 R60 N18
Last 7 of my VIN = WM15222
entire VIN = WMWZC5C55DWM15222
Old Dec 26, 2023 | 01:01 PM
Ok, yea if you replace it with a new thermostat you get this harness that a add on to the original
https://www.ecstuning.com/b-genuine-...r/12518614952/
If you know the thermostat replaced, then thats the wire kit you need. I would have to dig to see if i can find the older plug pre update harness. Just making sure.
Old Dec 26, 2023 | 05:55 PM
JoeTho's Avatar
JoeTho
Again, the new thermostat is virtually identical to the old one, so not sure why I would need the different wiring harness. And regardless, the broken plug is all I needed, and I found it today at the local BMW dealership parts dept. Four bucks, for an identical plug and the the little steel inserts, and I was able to rescue the little rubber grommets from the old broken plug.
So my big takeaway from this:
Locating oddball parts for a Mini is a lot easier if you can get to a friendly BMW parts dept with a patient and supremely competent parts manager. And while I'm thinking about it, the little replacement plug had a wide slot where the original had a narrow one on one side. Some of the little oem 2 pin plugs have a slot on one side or the other, but this replacement would fit as either.
Gabe3
Aug 15, 2023 02:14 PM
oxygenmini
Dec 14, 2021 08:46 AM
A383Wing
Electrical
Sep 20, 2018 01:15 PM
Minston
Oct 2, 2017 08:21 AM
scottwrightF1
Electrical
Apr 13, 2013 05:38 AM
