R60 Thinking to get 2011 mini copper s countryman
Old Jun 13, 2022 | 11:07 AM
rsoetidjo's Avatar
rsoetidjo
Are there anything I should know before get this car? Any engine , transmission or any major issues?Car have 120,000 miles. But looks like been taking care. Just don’t want buy a money pit.
Thank you
Old Jun 13, 2022 | 12:50 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
An 11-year old Mini might not be a full money pit, but it could be close if you have to take it to a mechanic for any maintenance items. If you can perform your own work on the car, you'll be much better off.
That being said, the 2011 turbo engine should be relatively reliable. The fuel pump might give you issue, they cost a lot, but they can be swapped out pretty easily. Manual transmission? The clutch could be on its way out with that many miles on it. The thermostat is know to only last 100k miles or so.
Find out what kind of maintenance history it has, and spend the money to get a dealer pre-purchase inspection.
Old Jun 14, 2022 | 02:01 PM
Rudeojr's Avatar
Rudeojr
Thank you
i bought one about 2 months ago a 2011 and in the first 2 weeks of owning it the high pressure fuel pump went out at a tune of $1500 repair. she runs great now. she only has 94k miles.
Old Jul 5, 2022 | 07:21 AM
bugeye1031's Avatar
bugeye1031
Moderator
Status?
Thank you
Did you decide to buy it?
Old Jul 10, 2022 | 01:40 PM
DOCtwo's Avatar
DOCtwo
I would walk away....
Bought mine 4 months ago. With in a week the Turbo blew up! $4800+ repair plus valve cover gasket and PCV valve. Thankfully Turbo and labor was covered under extended warranty.
A week later, the AC blend door actuator started acting up. Still need to figure out how to change that out. Anyone have an idea where its located? I've heard left and right and others have no clue.
Now the front strut mount bearings/bushings are out. Cracked even..... Cant find after market replacement shocks/struts that are complete kits. Unless buying coilovers and DO NOT need those for a daily driver. Can not find parts, or parts that are the correct fit!
About to send this car over a cliff! Or trade it somewhere else.
Carson01XJ
Apr 11, 2019 08:15 AM
cWade
17
Jan 23, 2015 05:17 PM
Karrock
Jun 8, 2012 12:41 PM
Karrock
Nov 3, 2011 08:17 PM
pre shrunk
21
Jan 9, 2010 07:36 PM
