R60 Drive Cycle
Old Jan 5, 2019 | 01:45 PM
Jwanck11's Avatar
Jwanck11
Drive Cycle
Have a Maniac Stage II tune.
Does anyone know the MINI drive cycle?
A couple of monitors show (INC): Oxygen Sensor Monitor and EGR System Monitor. All others are ready or have completed.
I am not sure what part of the drive cycle starts these tests. I cannot find MINI specific info and I could not find it in the manual.
Thanks!
Old Jan 9, 2019 | 02:37 PM
Jwanck11's Avatar
Jwanck11
I should have stated the mods:
maniac stage 2
maniac catless DP
NME CAI
Magnaflow 2nd cat back exhaust
The car runs and especially sounds awesome. There are no codes - permanent or pending.
Old Jan 25, 2019 | 04:00 PM
Jwanck11's Avatar
Jwanck11
Well, it seems the downpipe is the issue with the O2 sensor and there is no way it will set to "Ready." That sucks.
The EGR sensor is a different animal. Does anyone know where the EGR sensor is? The thing is there is no fault code which makes me think it is part of the tune...
Old Feb 1, 2019 | 11:20 AM
MrGrumpy's Avatar
MrGrumpy
Unfortunately from what I understand you will not get it to read a readiness state with Manic. The code out the CEL, but it will fail the readiness test. RPM has fixed this with their tune, but that doesn’t do much for you. As far as I know you can fail one readiness test for emissions testing in most states, but only one, so if there’s nothing else wrong it should pass emissions if that was the concern.
I do t know if this is what you were looking for or not. Good luck
Old Feb 5, 2019 | 04:49 PM
Jwanck11's Avatar
Jwanck11
Correct :( Nothing will set the O2 sensor as it's about heat and a catless downpipe simply will not generate the heat needed. No spacer solution would work. RPM fixed it? That is really interesting! I will have to ask about that.
The EGR sensor is also failing to set. I have no idea where this sensor is.
Roadsailer
Aug 24, 2020 10:52 PM
hong
Apr 8, 2016 08:37 PM
chip05
Jan 25, 2009 11:41 PM
momini
May 24, 2004 02:02 PM
