R60 Interior dome light fixture removal
Old Nov 13, 2018 | 12:12 PM
MiniRza's Avatar
MiniRza
2013 Mini Cooper S Countryman (R60)
Does the interior dome light fixture (the entire housing, not just the bulb cover) simple pull out and away from the headliner? I have pulled with a little force and it doesn't seem to want to come out, but I am hesitant to pull harder because if it is secured in with screws or something, I do not want to break it.
Reason for wanting to remove it is because when I was replacing a bulb, I accidentally turned the bulb seat housing and in fell up (into the fixture/roof) and I need to secure it back to the fixture. (I know now that the bulb seats are only installed with a half turn)
Thanks in advance!
Old Nov 20, 2020 | 05:58 PM
E Clanin's Avatar
E Clanin
Dome light removal
Thanks in advance!
start on the end closest to passenger window. Slide a trim removal tool (plastic) between the end and the liner a bout 1/4 inch and give it a good tug! The two posts have split and wide teeth that go into the mounting holes. It feels like it would break but it does not. It’s in tight.
Old Nov 24, 2020 | 12:55 PM
https://www.ecstuning.com/b-ziza-par...-kit/r60ledkt/
Install PDF
http://bd8ba3c866c8cbc330ab-7b26c6f3..._Light_Kit.pdf
Old Jun 29, 2022 | 02:44 PM
varma1986's Avatar
varma1986
Hi. Do U have a info or link on how it is done on the F60?.
Old Jun 30, 2022 | 01:04 PM
Sorry we have not messed with the f60, its a factory LED car.
https://www.realoem.com/bmw/enUS/sho...diagId=51_9558
https://www.realoem.com/bmw/enUS/sho...diagId=61_3300
Old Jun 30, 2022 | 01:44 PM
varma1986's Avatar
varma1986
I have marked the 2 pins with arrows. This is my 2018 MINI Cooper CountryMan F60.
In the F60, The dome reading lights can be displaced from its housing by making a strong pull holding the module on the end that is closer to the rear view mirror. The pull must be a strong & courageous pull in the downward direction. As the 2 pins bend a little and make a loud noise> the module will disengage from its housing and drop down.
When the module needs to be put back, the 2 metal pins need to be bent back into place and gently jammed back into the housing.If the Pins are not adequately bent> to lock into its housing> the module will be loose & wobbly. I opened this dome reading lights module to check and see if there was a unused connector hidden underneath for retrofit of an auto dim mirror.I could not find any loose connector for the rear view mirror.
TBangin23
Aug 23, 2010 10:08 PM
Milton Mini
May 8, 2009 12:56 PM
mplatt911
Jul 2, 2008 05:19 AM
amorican
Electrical
Oct 1, 2007 07:14 PM
ecl3x
Mar 1, 2004 03:06 AM
