I have this problem ultimately usually when i am with 5th and 6th gear with almost full throttle.I had remaped the ECU to 219Hp but this was happening once every semester.Now is happening almost every time i m taking out the car and pressin it.I can t find what is the problem.I changed twice the ECU programming but the problem is still there.When i stop the engine and start it again the check engine light is disappearing and full power is coming back.The meccanic can t find anything wrong.The tubes are ok.Maybe is someone of the sensors but which one?
Anyone else with the same problem?
So you tuned the car and expect someone else to diagnose it? Even if you gave us all the details I doubt we can help. But as a start what OBD error codes are popping up? And what year, how many miles, etc. etc. HPFP been replaced?
The one who tuned the car didn t helped me a lot till now and the meccanic too.The errors are missfires,super knock to some cylinders,i think also negative pressure and also something else that i have to ask again to remember it.Is the R60 S All4 2010 with 75.000 km with a remaped ECU and a more free airfilter(nothing else is changed).After a good search and reading yesterday i think the problem is the diverter valve(or the carbon on the valves).I have already ordered a new valve.I let you know.
I must buy also a multigauge to check during the drive the engine.I think the one which suits to me is the PLX cause has a retro style and not the P3Car cause i have to put it into the airvent(and i dont like the idea).
